Inductor or Capacitor? Need help!!!
jrd78ep
Mar 21, 2013
13
Mar 21, 2013
13
Hello i am new on this forum....i am troubleshooting an intrument...i found a mosfet with inductor (label L3) connects at drain and source...when i check the inductor it is fuse-open (read in Mohms). Wondering if it is really an inductor or not...because it is not normal to me to see inductor at drain & source...
Any idea guys? thanks for the help. (PLEASE SEE ATTACHED FILE FOR THE PHOTO).
Electrobrains
Jan 2, 2012
259
Jan 2, 2012
259
So you mean varistor also can be labeled "L3" ? thanks for the reply.
No, that would be very strange, but placing an inductor over Drain-Source of a MOSFET would be even stranger!
It could happen in some rare oscillator circuits or the MOSFET could be used as a variable resistor to change the Q-factor of the inductor.
Anyway, the component sure looks like an smd inductor.
jrd78ep
Mar 21, 2013
13
Mar 21, 2013
13
Now i'm getting confuse :-(
Please help get a conclusion...since i measured it fuse-open and looks like smd inductor...do i need to replace it?
Just to add up..this mosfet source pin is connected to ground. Thanks.
Electrobrains
Jan 2, 2012
259
Jan 2, 2012
259
Well. some things in life are not so obvious, especially if we don't have a handbook...
Maybe you have to analyze the circuit a bit more. What kind of instrument is it? What is the name of the MOSFET (cannot read it)? Where does the drain connect to? Can you get a circuit diagram from the manufacturer?
jrd78ep
Mar 21, 2013
13
Mar 21, 2013
13
Yes you're right...so i drawn the schematic to give better insight...please see attached file....hoping u can share now exact idea....thanks alot.
Electrobrains
Jan 2, 2012
259
Jan 2, 2012
259
Seeing that schematic, it's most probably a protection component. The varistor alternative definitely got support.
What is the name of the MOSFET?
jrd78ep
Mar 21, 2013
13
Mar 21, 2013
13
Any update from you today Electrobrains??? I had sent u already the mosfet number....thanks
Electrobrains
Jan 2, 2012
259
Jan 2, 2012
259
Probably it's an IRL540NS, a rough power MOSFET.
What is the problem? What doesn't work in your "instrument"?
Does the output not switch?
