Inductor help
Discussion in 'Electronics Homework Help' started by ElectStudent, Apr 8, 2014.
  1. ElectStudent
    ElectStudent
    13
    Apr 8, 2014
    Please see attachment.
    In this circuit, the graph shows that the current rises linearly.
    However, wouldn't there be a limit to how much it rises and is it actually linear because the inductor should resist current changes shouldn't it?
  2. ElectStudent
    ElectStudent
    13
    Apr 8, 2014
    Are these graphs correct?
  3. BobK
    7,682
    1,688
    The equation for an inductor is
    dI/dt = V/L
    So, with a fixed voltage across the inductor, the current will rise linearly. This is with ideal components, i.e. a voltage source that has no current limit or internal resistance, and an inductor with no series resistance. In the real world it will be limited and non-linear as you imagine.
  4. ElectStudent
    ElectStudent
    13
    Apr 8, 2014
    Thank you that helped a lot. I was also wondering how the current can rise so fast in an inductor? Because i was thinking inductors resist current change
  5. (*steve*)
    25,490
    2,831
    The rising current *is* the inductor resisting a change in current.
    It doesn't instantaneously rise to some figure does it?
    Rather than stopping at some point, if the inductor saturates (which a theoretical inductor won't) the current will spike.
