C
Clifford Heath
I've developed an MSP430 (TI low-power 3V uP) device that drives a
small piezo in push-pull from two pins at 2KHz, and it's not loud
enough. The device has a requirement of very low quiescent power,
and although it flashes an LED at the same time, should be audible
to an older person by the side of a noisy road, so far as possible.
I realise that frequency range is a problem, hence the LED .
I haven't finalised selection of the piezo, but I see different
ones with capacitances ranging around 0.02uF. I don't want to
produce a higher drive voltage all the time, as they don't beep
very often and at present the thing idles with the RTC running at
under 1uA.
I was thinking of trying the following arrangement:
Connect each end of the piezo by a series L (SMT inductor?) to +3V,
and each end also to the collector of an NPN BJT in common emitter
mode. Drive the base of each transistor in push-pull, and let the
inductors ring the voltage, hopefully up to 6V or so, as in a
boost-mode power supply.
It doesn't seem crucial to me to get the thing running at resonance,
but if possible, I guess I'd calculate the frequency using half the
piezo's capacitance and the L, aiming for the natural resonance of
the piezo - does that sound right?
Anyhow, I'm confident that this drive arrangement will work, but
is there a better way? Am I missing something? is it sensible and
possible to get SMT inductors in a suitable size?
Clifford Heath.
under 1uA.
Clifford Heath.
