Induction Proximity sensor issue
Discussion in 'Sensors and Actuators' started by naeemidrees, Jan 17, 2020.
  1. naeemidrees
    naeemidrees
    8
    Jan 17, 2020
    I am using induction proximity sensor in my circuit. Some time specially in winter sensor do malfunction. Means sensor randomly trigged. I am use NPN type sensor.
    Please help me.
  2. bertus
    bertus Moderator
    1,343
    533
    Nov 8, 2019
    Hello,
    Do you have a datasheet of the sensor to post?
    That way we can see the properties of the sensor.
    Bertus
  3. Minder
    Minder
    3,035
    642
    Apr 24, 2015
    What would the typical 'winter' temperature experienced by the sensor?
    M.
  4. naeemidrees
    naeemidrees
    8
    Jan 17, 2020
    Data sheet Attached
  5. naeemidrees
    naeemidrees
    8
    Jan 17, 2020
    In my country min temperature will be 5C but with dry.
  6. naeemidrees
    naeemidrees
    8
    Jan 17, 2020
    I am using Atmega32 uc.
  7. bertus
    bertus Moderator
    1,343
    533
    Nov 8, 2019
    Specifications (cont.)
    Ambient temperature
    Operating : -25° to +70°C (-13° to +158°F)
    Storage : -30° to +80°C (-22° to +176°F)
    What is the temperature in winter?
    Do you have a complete schematic to share?
    Bertus
  8. Minder
    Minder
    3,035
    642
    Apr 24, 2015
    What form does the 'flag' take that triggers the Prox?
    What is the nature of the input, any opto etc?
    M.
    bertus likes this.
  9. naeemidrees
    naeemidrees
    8
    Jan 17, 2020
    I am using opto PC817
  10. naeemidrees
    naeemidrees
    8
    Jan 17, 2020
  11. bertus
    bertus Moderator
    1,343
    533
    Nov 8, 2019
    Hello,
    I assume you are using a single 24 Volts power supply.
    The schematic suggests a dual 24 volts power supply, that would give 48 Volts on the sensor.
    The current through the led of the 817 will be about (24 -1.2) V / 5600 Ohms = 4 mA.
    Perhaps lowering the resistor value may give a more stable result.
    Try a resistor of 2200 Ohms in stead of the 5600 Ohms.
    Wich version of the PC817 are you using?
    There are 4 different sensitivity ranges.
    Bertus
  12. naeemidrees
    naeemidrees
    8
    Jan 17, 2020
    I am using PC817 - 1 Channel type.
    This circuit drive two 24v solenoid. Mean noise environment.
  13. naeemidrees
    naeemidrees
    8
    Jan 17, 2020
    I am waiting of ur reply.
  14. bertus
    bertus Moderator
    1,343
    533
    Nov 8, 2019
    Hello,
    As I asked before, wich version of the PC817 are you using:
    Also did you try a different resistor for the IR led of the PC817?
    Also what is the value of R5 in your schematic (the collector resistor of the opto)?
    Bertus
