I do have one with inductance, but feeding a signal into the inductor
and resistance should give you a voltage that will indicate inductance.
I can't remember if the meter i have also measures capacitance, but
the procedure is the same.
Basically...
Put a sine gen on a RL cct and use the DMM to measure the AC level
across the coil.
Then do math..
Beware of the limitations and restrictions..
D from BC
