Indicator LED placement
Discussion in 'LEDs and Optoelectronics' started by pizoman, Mar 29, 2014.
  1. pizoman
    pizoman
    51
    Mar 10, 2012
    I'm trying to figure out where I can place indicator LED's on my circuit for a simple motor controlling circuit using the arduino. I'm using a TIP120 transistor. I want to place a LED to indicate the circuit is on and one that indicates off where the motor isn't moving. To my understanding, the TIP120 transistor connects the collector to emitter when the arduino sends a "high" signal via the base. So when the collector is connected to the emitter, the "on" status led will light up whereas the "off" status led will not light up.
    If I placed an led in parallel to resistor R5 when the arduino sends a low signal to the base, will the voltage travel from base to emitter and so the motor won't turn on indicating that the circuit is in an "off" state thereby the "off" status led lights up and the "on" status led does not light up. I've attached a diagram of what I'm trying to do. Sorry if my wording is confusing, it's getting late here on my end.
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,079
    Dec 18, 2013
    Try this it might work. Oh your top LED and resistor is shorted.
    Adam
  3. pizoman
    pizoman
    51
    Mar 10, 2012
    Arouse1973, can you explain how your circuit works? With the way you connected the motor, straight to ground, wouldn't the motor just turn on the entire time?
  4. davenn
    davenn Moderator
    13,432
    1,807
    V1 is the power supply NOT the motor
    L1 M is the motor
  5. Arouse1973
    Arouse1973 Adam
    5,164
    1,079
    Dec 18, 2013
    Yep that's correct. Thanks Dave :)
  6. pizoman
    pizoman
    51
    Mar 10, 2012
    Thank you, it works. However, the "ON" led (D2) fades out when the motor turns off. Is this due to residual voltage that's still flowing in the circuit immediately after a LOW signal is sent to the base of the transistor? Is there any way to get D2 to not fade out?
