Shawn said:
How do you go about increasing voltage from a lower voltage to a higher
voltage. This will be used to run a 24 volt stepper motor.
-Shawn
You will need a boost voltage converter- typically, this is an oscillator
and inductor, diode and capacitor, and a regulator to smooth it out. Switchmode
power supplies can do this. But be aware that if you boost 5 volts to 24 volts,
whatever current your motor draws will also be multiplied by about 5 times plus
losses.
What that means is if your motor draws an amp at 24 volts, the switching
supply will draw about 5 amps at 5 volts.
Cheers!
Chip Shults
My robotics, space and CGI web page -
http://home.cfl.rr.com/aichip
