increasing the voltage out from a 7812 ?
M
mark krawczuk
hi, is there any way to increase the out put voltage from a 7812 voltage
regulator ?
i need to increase it to about 13.8 volts .
thanks, mark k
"Are you still wasting your time with spam?...
There is a solution!"
Protected by GIANT Company's Spam Inspector
The most powerful anti-spam software available.
http://mail.spaminspector.com
L
Lord Garth
regulator ?
thanks, mark k
Place 3 diodes in the ground leg and you'll raise the output by 1.8 volts or
use a
variable resistor there instead. The input must be at least 2 volts above
the
output in all cases however.
