Improve rise time on monostable multivibrators?
Discussion in 'Electronic Design' started by Jason, Jul 16, 2004.
  1. Jason
    Jason Guest
    I'm building a circuit that uses a few monostables (LS123's) to
    generate pulses. The resulting pulses end up with about 100 ns rise
    time, and I need to get this down to 15 ns. Any ideas on how I can do
    that?
  2. Tim Wescott
    Tim Wescott Guest
    * Use a faster technology, such as a 74VHC123.
    * Minimize the load capacitance on the pin.
    * If you can sacrifice fall time and power consumption, use a pullup.
  3. I read in sci.electronics.design that Jason <>
    Stop using the LS family.
  4. John Larkin
    John Larkin Guest
    I'm surprised that any LS part would be that slow. I thought they were
    in the 7 ns Tr/Tf range. The simpler gates had typ prop delays of 8
    ns.
    People don't make one-shots much any more; they've fallen out of
    favor.
    John
  5. Joerg
    Joerg Guest
    Hi Jason
    One method would be to simply hang a fast Schmitt trigger onto the
    output. If you use an LVDS chip you could achieve ramp times under
    1nsec. But I believe the LS' jitter will cause this ramp to meander
    around quite a bit.
    Regards, Joerg
