Impossible Circuit - Any Ideas?
Discussion in 'Electronic Design' started by aaronej, Nov 22, 2006.
  1. aaronej
    aaronej Guest
    I saw this the other day and I was mystified. The circuit has a green
    and red light bulb, and a green and red switch. Initially, the red
    switch turns the red bulb on and the green switch turns the green
    switch on. When both switches are on, both bulbs are on
    Here's the catch:
    When you switch the Red and the Green Light bulb, the red switch still
    controls the red light bulb and the green switch still controls the
    green light bulb.
    Can anyone explain or diagram this?
  2. Phil Allison
    Phil Allison Guest
    ** Groper alert !!
    ** The supply is AC and the bulbs have diodes fitted inside them, wired in
    series with the filament.
    The switches also have diodes in series with them.
    So, the lamp sockets are simply wired in parallel and it make no difference
    which is used.
    ......... Phil
  3. Jamie
    Jamie Guest
    sure, they had diodes on the switchs and bulbs.
  4. Iwo Mergler
    Iwo Mergler Guest
    There is also an alternative series circuit:
    +-----+-(X)-+------+-(X)-+---+
    o |
    AC ~ |
    o |
    Again the diodes are inside the bulb socket.
    You can swap the bulbs with baffling results
    and it won't work with one bulb removed. ;-)
    It's a fun circuit when built on clear perspex.
    Kind regards,
    Iwo
  5. Mike
    Mike Guest
    It's a "magic trick" ... sounds like ... US Patent No 5790013 ?
    See http://www.freepatentsonline.com
  6. Mike Monett
    Mike Monett Guest
    Mike, how on earth did you find that patent?
    There's no way I could have searched the patent database and come up with
    that number.
    You should patent your search method:)
    Regards,
    Mike Monett
    Antiviral, Antibacterial Silver Solution:
    http://silversol.freewebpage.org/index.htm
    SPICE Analysis of Crystal Oscillators:
    http://silversol.freewebpage.org/spice/xtal/clapp.htm
    Noise-Rejecting Wideband Sampler:
    http://www3.sympatico.ca/add.automation/sampler/intro.htm
  7. Donald
    Donald Guest
    This is so silly.
    A patent !!! for this !!???
    No wonder many say that the US Patnet office is in dire need of house
    cleaning.
