Impedance of digital inputs
P
Patrick
Would it be safe to say that ALL digital inputs (pins on
microprocessors, microcontrollers, gates, etc.) are always high input
impedance? i.e. When doing circuit analysis is it okay to model a
digital input as a very large (100K or higher) resistance to ground?
Thanks in advance...
K
Kevin Aylward
Essentially yes, if they are *CMOS*. They look like, say, 1p-10p
capacitance, with a very high dc impedance. For the most part they can
be considered open circuits for DC. A more accurate model would be to
include diodes from the inputs to the supply rails to model leakage.
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
P
Patrick
Sounds good. What about digital inputs of other logic families, e.g.
TTL? If I remember correctly TTL inputs draw a few micro-amps of
current with a logic HIGH (5V) input.
John Fields
impedance?
John Fields
err....do people still use TTL?
Do it matter?
His question was:
"Would it be safe to say that ALL digital inputs (pins on
input impedance?"
and the answer is clearly "no".
P
Pooh Bear
They draw a hell of a lot more when LOW.
Graham
P
Pooh Bear
Rich said:
Actually, they're _sourcing_ current when low. ;-) ;-)
Cheers!
Rich
Yeah, yeah, I know ! Didn't want to spoil the flow of it though.
Graham
K
Kevin Aylward
Well, actually, no they are not. There are sinking electrons *into* the
input!
Kevin Aylward
[email protected]
John Fields
input!
They're sourcing _conventional_ current, Kevin.
R
Rich, Under the Affluence
The way kewl thing about this is, it doesn't matter! To switch from
conventional to electron flow, just change all the pluses to minuses,
and vice versa. ;-)
The thing that really weirds me out [but The Philosophizer loves it]
is that, in all of the equations that relate electricity and
magnetism, you can swap those two, and the answers still come out
right!
I'm working on a 3-D diagram of the two 7-dimensional hypertoruses
that the Universe is derived from...
Cheers!
Rich
John Fields
They can't. Conventional current is imaginary...
So's the square root of minus one, but that doesn't stop us from
using it.
Don't be an ass, Kevin. We all know that and we all use
conventional current every day.
P
PeteS
On the OP question, I just had an interesting experience with a Xilinx
part. In *unprogrammed* mode, the bus hold circuitry is active in
series with an equivalent resistor of about 25k to the I/O pin.
I caught that just as I was connecting things up to it (because I
wanted to leave it unprogrammed for initial testing of other parts of
the board) and had to whip up a simple piece of verilog to force inputs
to *be* inputs and outputs to be at the suitable level. It didn't do
anything else, so I simply had a bunch of assignments.
The old rule of thumb that FPGA IO pins are inputs when unprogrammed
doesn't always hold ;)
Cheers
PeteS
Jasen Betts
and vice versa. ;-)
right!
One exception is the Hall effect.
that one depends on the sign of the charge on the charge carriers and has
been measured to have the opposite sign in P-type semiconductors than it
does in regular metals and N-type semiconductors.
huh?
Bye.
Jasen
