Image stabilization
Discussion in 'Misc Electronics' started by Yugo Hurvitova, Aug 13, 2005.
  1. Is there an open source Windows/Linux code for real-time image stabilization
    of live video captured from firewire ?
    By image stabilization, I mean minimizing the disturbances caused by small
    camera movements/shake.
  2. Yes, there is. There are optical stabilizers built into video cameras
    that use a prism attached to a weight. There are electronic stabelizers,
    that use fuzzy logic to move the image subregion within a larger image
    capturing plane.
    There is also mpeg compression which uses motion vectors on a
    block-by-block base. By itself, it does not compensate for motion, but
    it gives you great information about motion vectors inside the image
    that you can use. Stabilization then could be done by adjusting H and V
    sync.
