A
Adam
[I apologize if this ends up being double posted, I originally submitted
a post similar to this one better then 24 hours ago via Google Groups
but it seems to have been absorbed by the ether. Because of this I am
rewriting and posting via my ISP's NNTP server and encouraging others to
avoid Google Groups at least until they get their act together.]
I was given a pile of parts that amounted to an Apple iMac DV 400
(http://www.lowendmac.com/imacs/400.shtml) awhile back. The guy that
gave it to me said that it didn't power up but that he had no idea why.
I know that iMacs of this vintage were notorious for blowing their PAV
(power, analog, video) boards. All the Mac people that I have talked to
say that the only way to fix it is to replace the PAV board because the
boards weren't fixable (such a typical Mac user solution). I don't want
to spend the $75 to buy a new board when I know that I should be able to
fix it with a few bucks worth of of the shell electronics.
After reassembly I plugged the unit in and hit the power button. All I
got was a quick blink of the power LED and a click through the speakers.
If I tried to turn it on again nothing would happen unless I had
unplugged it for a few minutes. The same thing happened when I tried
using an external monitor (this model has a standard 15 pin VGA
connection on the back) so I doubt that the flyback is the culprit.
Next I disassembled the unit to get a better look at the PAV board. I
carefully inspected it for cold solder joints and the like. I've seen
better PCB manufacturing but all in all everything looked okay. One
thing did jump out at me. The top of the large 560uF 400V capacitor
designated C905 on the PCB was domed (out not usually a good sign).
Unfortunately I don't have a ESR meter so I am unable to verify that it
is bad. Is there anyway I can test this cap without an ESR?
With my hypothesis about the capacitor I search the web for "imac" and
"C905" and found a page
(http://homepage2.nifty.com/tamaru/iMacDV/iMacDV_1.html) where the
author seems to be documenting the same problem although I can't be sure
as it's all in Japanese. On this page there are also a number of
pictures of a power IC that on my board is labeled as IC901. It would
appear that this is a Fairchild KA5S12656
(http://www.fairchildsemi.com/ds/KA/KA5S0965.pdf).
Does anyone have any experience working on these iMacs? Will replacing
the cap and/or the power transistor get this beast up and running again?
Any thoughts on where I can find the Fairchild part cheap (Digi-Key
doesn't list it and I doubt that Fry's or Radio Shack are going to stock
it). I'd love to find somewhere in the Portland, Oregon metro area that
stocks it or is able to get it easily (and inxepensivly).
--adam
--adam
