Iiyama 19" LCD power problem.
Discussion in 'Electronic Repair' started by Jack, Mar 4, 2007.
  1. Jack
    Jack Guest
    Iiyama Prolite E481S goes dead after about 10-15 min. of usage. After it's
    disconnected from supply for awhile, it starts up normally again.
    I have ESR measured the capacitors, without success. Anybody have any inside
    on this problem?
    I searched the web and found out that it's a common fault, but have not
    found solution yet.
    Jan
  2. Jack
    Jack Guest
    As soon as I had sent this message, I found the fault:
    L101 on the power supply board had a dry joint on one end. ;-)
    Jan
