IHF Noise Measurement Weighting
Discussion in 'Electronic Equipment' started by Tak, Jun 4, 2005.
  1. Tak
    Tak Guest
    I hope any guru here would help me on this.
    I want to have the filter parameter for IHF noise measurement
    weighting. They are so called A, B, and C weighting.
    I vaguely remember parameters, say A filter's low-cut is
    somewhere 800Hz by 6dB/oct, and high-cut is around 5kHz by
    12dB/oct.
    B is wider, and C is further wider.
    The parameters I want are:
    Weight Low Slope - High Slope
    A xxxHz xxxdB/oct - xxxHz xxxdB/oct
    B xxxHz xxxdB/oct - xxxHz xxxdB/oct
    C xxxHz xxxdB/oct - xxxHz xxxdB/oct
    Thanks in advance
    Tak
  2. Dale H. Cook
    Dale H. Cook Guest
    Those parameters are determined by published graphs. You can either
    purchase a copy of IEC 60651, or see a standard reference such as The
    Audio Cyclopedia.
    Dale H. Cook, Chief Engineer, Centennial Broadcasting,
    Roanoke/Lynchburg, VA - WZZI / WZZU / WLNI
    http://members.cox.net/dalehcook/starcity.shtml
  3. Tak
    Tak Guest
    Thanks, Dale.
    Appreciate the information.
    I have ordered G. Ballou's "Handbook for Sound Engineers" at
    Amazon. It's 2005 edition. I hope this carries the graph.
    I found the "Audio Cyclopedia" seems a bit old.
    Looked at IEC standards for 60651 as I knew the number before
    posting this newsgroup, but could not find it.
    Tak
