Really? Decades of engineering work out the window. Most of us haveshot
for somewhere between 50 and 80 dB and found that span decent to work with.
Sorry, the RF amplifier stage sets the noise figure to a first
approximation. All the stuff behind is is second order at best.
I would have put it as the RF amplifier and mixer but once past there
it is more like a second order approximation that the noise numbers
are set.
sqrt(1^2 + 0.5^2) = 1.12
If your RF stage only gives you 6dB of gain it dominates the noise
issue.
Yeah, I know. Deep space picovolt work requires something on the orderof
100 dB (what a crystal bitch to tame)
The earth bound end has the advantage of being able to spread things
out. The amazing stuff is the stuff that has to be kept light enough
to launch.
and crackerbox AM radio can get by
with 40 dB, but 20 dB is laughable.
An old tube AM radio I fixed many years back had less than 40dB in the
IF. The gain was something like 45 or 50. It could receive about the
same stations as I could get on my crystal radio. Its only advantage
was that you could hear them one at a time instead of all mixed
together. I think that even 40dB may be a little low for a good AM
radio.
Who is this idiot? Wasn't he the one that was trying to adapt AM sideband
principles to FM modulation? Somehow I don't think either Bessel OR
Armstrong is his friend.
Since the whole world is going digital, I'll give this one away:
If you single side band modulate the upper side band with a signal and
modulate the lower side band with minus the signal and radiate the two
sidebands as the carrier, you have a signal that can still be
understood if it get clipped along the way. It still sounds like hell
but you can make out what is being said.
