Idiot with coffee fetish
MJ74
Sep 21, 2018
10
Sep 21, 2018
10
Hi, as the title of this thread indicates, I'm completely at a loss when it comes to electronics. I am trying to remedy this by learning the basics. I have two goals, firstly to be able to create small electronic circuits with my son so he gains an interest and some knowledge and, secondly, to turn a power drill motor into a slow turning drive for a coffee grinder dedicated to turkish coffee grind.
I look forward to learning from the members here and hopefully gaining the ability to get this grinder working.
Cheers MJ
Harald Kapp
13,720
13,720
Welcome to EP.
thumbs up :)
I recommend to use gears to reduce speed. A power drill motor's speed can be reduced by e.g. a pwm drive, but that comes at a loss of power (lower speed = lower power input = lower power output).
MJ74
Sep 21, 2018
10
Sep 21, 2018
10
Thanks Bluejets, I'll take a look. I've been watching a lot of tutorials for beginners on YouTube as well.
Bluejets
Oct 5, 2014
6,924
Oct 5, 2014
6,924
No worries....wish this stuff was around when I was a kid.
We had to learn from text books that cost and arm and a leg and were many instances, way out of date.
This site covers so much ....it's great.
Word of warning, don't believe everything you see on youtube or instructables.
MJ74
Sep 21, 2018
10
Sep 21, 2018
10
Thanks Harold, I thought of that but as I have been using a cordless drill held on at one third power to achieve a rpm of about 60 or so, I thought why not buy a power drill and mount the motor on a stand and then just wind back it's speed. If I can lightly hold on the drill to achieve the rpm and the torque is still sufficient then gears may, or should not be needed.
Would it be as simple as replacing the drill's trigger with a pwm?
Harald Kapp
13,720
13,720
An electronic kit ("Elektronik Experimentierkasten") may be a good starting point. Not only does (or at least should) it contain instructions and all required parts, usually an easy means of connecting the parts without soldering is included. Good for starters. Switch to breadboards like this later once you (and your son, of course) got the hang of it.
MJ74
Sep 21, 2018
10
Sep 21, 2018
10
I watched and read some articles with some kids doing simple circuits with a bread board. Stuff like getting led lights to shine and a basic motor and computer set up. I think your tip of the Experimentierkasten is a good one.
Bluejets
Oct 5, 2014
6,924
Oct 5, 2014
6,924
That already has speed control in the trigger.
Mains speed control of these motors is via thyristor and phase control.
PWM is for dc battery motors etc.
MJ74
Sep 21, 2018
10
Sep 21, 2018
10
Right. Things I have to learn.
Hopefully I can take it apart to mount it and somehow slow the speed down enough with the existing trigger without having to physically hold it on.
Bluejets
Oct 5, 2014
6,924
Oct 5, 2014
6,924
Leave it as is and simply rig up a screw clamp around the trigger and the handle.
MJ74
Sep 21, 2018
10
Sep 21, 2018
10
I did have that thought but then I was taken by the desire to make it look pretty.
dave9
Mar 5, 2017
1,188
Mar 5, 2017
1,188
The motor could just be used with the drill's gearbox, but the motor is the easy part. By the time you buy parts and fabricate the grinder portion, you might as well have just bought a ready made grinder. These things do exist, so seems like a case of reinventing the wheel, except at great time lost to do so, probably for an inferior result as the world has had teams of people developing coffee grinders for over a century.
I suppose you could buy one ready made, rip its motor out and stuff the drill motor in for the cheapest, easiest way to do this, but why?
Bluejets
Oct 5, 2014
6,924
Oct 5, 2014
6,924
Drills such as shown have the motor and the gearbox components held in place by the casing.
No such thing as simply pulling out the motor to use elsewhere.
dave9
Mar 5, 2017
1,188
Mar 5, 2017
1,188
^ Depends on the design, generally the gearbox has screws on the inside wall going into the end of the motor casing and those motor casing tapped holes can be used with same or longer screws to mount the motor elsewhere.
For example that can be seen on the following diagram as two screws (a pair of part # 54). That will keep those two together, or allow mounting the motor separately, but to mount the motor and gearbox assembly outside of the drill casing you could simply fabricate a mounting plate to go around the gearbox, OR in some cases if the drill has a clutch on the gearbox, that too is fastened onto the gearbox with screws that can be removed and reused to mount the gearbox with the motor attached.
Will it stand up to the rigours of grinding long enough to be worth doing? Given enough experimentation, it's do-able but on the first try? Probably a long road ahead to make a cumbersome steampunk looking thing that wasn't worth the bother because coffee grinders exist, and are fairly inexpensive too ~ $15 USD while a DIY grinder may take more in materials than that $15.
