Identifying parts
Discussion in 'Electronic Basics' started by Ken O, Jul 6, 2006.
  1. Ken O
    Ken O Guest
    Hi
    I have several part here, I think they are resistors, but the color used are
    confusing.
    I put a jpg here:
    http://www3.sympatico.ca/lerameur/
    there are 4 types.
    the first is red - blue- red, they gave me 2.8K on the ohm meter
    the second: is red red green brown giving me 1.5K
    the third (by itself): orange white brown giving me 450 Ohm
    fourth: it has 5 colors.. brown black black orange brown giving me 99K
    I heard inductors can look like resistance sometimes. Can someone help me
    out here ?
    Also, does the base color of the resistor matter. Most of the one i have
    have a beige background. But from the picure, one is green , and the rest
    are brown
    the page mightbe long to load because I kept a high resolution picture so
    you can really see them.
    thanks
    ken
  2. Ralph Mowery
    Ralph Mowery Guest
    The first one should be a 2.7 K 10% resistor. Red,violet,brown,silver (has
    to be violet as blue 2.6 K is not a normal 10% value)
    The second should be brown,green,red,red to give a value of 1.5 K (not sure
    what the second red is for)
    Third is orange,white,brown,silver for a value of 390 ohms at 10 %
    Last is 100,000 K and again I am not sure what the last band is for.
    The 2.7 K and 390 resistors look to be the older carbon composition units.
    I have seen inductors that looked similar to the othes but the resistance
    values you are getting are way too high for that . Mabye 10 ohms at the
    most, more like likely under 1 ohm for an inductor.
    The body color seldom maters as far as the value. Years ago there was a
    coding called body,end,dot where the body was the first value, one end was a
    color and then a dot near the middle was the multiplier.
    You should look up the values that the standard 10 % resistors come in and
    you will see where the color bands can fall. The value you read on an ohm
    meter should be close to this value (within 10 % or less).
  3. Ken O
    Ken O Guest
    Alright, so THER ARE all resistance. i was very confused with the extra
    color band.
    I posted a second picture with some more resistances, but thats ok now, If
    they are resistances, I can confirm the the values on my ohm meter
    thanks
    ken
  4. Ken O
    Ken O Guest
    got this fromt the net
    5-band identification is used for higher tolerance resistors (1%, 0.5%,
    0.25%, 0.1%), to notate the extra digit. The first three bands represent the
    significant digits, the fourth is the multiplier, and the fifth is the
    tolerance. 5-band standard tolerance resistors are sometimes encountered,
    generally on older or specialized resistors. They can be identified by
    noting a standard tolerance color in the 4th band. The 5th band in this case
    is the temperature coefficient.
  5. HKJ
    HKJ Guest
  6. Ralph Mowery
    Ralph Mowery Guest
    Good for you Ken. If you do a Google search for resistors +color code you
    will get many charts. Not all resistors are coded the same . Just as with
    many things, you have to know what the maker is doing with the markings.
  7. JeffM
    JeffM Guest
  8. jasen
    jasen Guest
    2% tolerance
    more like could be orange-white-brown- and no tolerance band nothing for 20%
    tolerance.
    1% this time.
    these days it seems to indicate what process was used to make the resistor
    IIRC tan is carbon film and pale blue is metal film.
  9. John Fields
    John Fields Guest
    That's an error. It's red (2) violet (7) brown (1), and the third
    band indicates the number of zeros which follow the first two
    digits, so the value of the resistor is 270 ohms. The silver band
    indicates a tolerance of +/- 10%
    That's an error. It's brown (1) green (5) red (2 zeros) and the
    second red means its value has a tolerance of red (2)%.
    It should be orange(3) white (9) brown (1 zero) = 390 ohms, but the
    10% tolerance could allow that to go up to 429 ohms with the
    remaining 21 ohm error being the fault of your ohmmeter.
    Or, the resistor might be out of tolerance; it looks pretty beat up.
    On those, the wide brown band indicates that they're 1% resistors,
    and the colors mean: brown (1) black (0) black (0) orange (3 zeros),
    making them 100000 ohm resistors, as evidenced by your measurement
    of 99k.
  10. Ken O
    Ken O Guest
    Thanks for the information. I ended up throwing most of them in the garbage.
    They dated many many years and gave me weird readings. I do not know if
    resistors have a life period, but I am not taking any chances.
    ken
  11. Chris
    Chris Guest
    Hi, Ken. Hold off on throwing them out, except for the one 390 ohm
    resistor (group 3) -- it's obviously broken.
    Resistors don't have date codes -- they basically last forever.
    Eventually, with enough age the leads become oxidized enough that it's
    difficult to solder them, and they're cheap enough that it's easier to
    throw them out than burnish the leads.
    There's one exception to that, having to do with the first and third
    set of resistors. These are carbon composition, and they tend to
    absorb water vapor out of the air over time (years), which tends to
    lower their resistance value. You see, carbon comps are meant to be
    run at or near rated wattage, and their internal power dissipation is
    supposed to be enough to burn off any absorbed water. After a number
    of years storage, that can change.
    The solution is to put them in a pan, and throw them in an oven at 250F
    for an hour or so. That liberates the water from the carbon comp, and
    once they cool off, their resistance will be nearly its original value.
    The other resistors have a sealed coating over their resistor body, and
    aren't changed by storage. Again, they'll last practically forever.
    Good luck
    Chris
