identifying delay line pins & function.
Discussion in 'Electronic Components' started by dooj, Jul 4, 2007.
  1. dooj
    dooj Guest
    Hi all, i'm trying to find info on a couple of delay lines pulled from
    an old philips VCR. I've not been able to find any data sheets on the
    web for these devices so hopefully someone here can give me a hint.
    I have two of these delay lines both with a KSS logo -
    Delay line MS -19 400030 82H34, blue plastic package, (34x24x6mm),
    with four pins
    Delay line MS -18 400040 82J14, cream/white plastic package,
    (64x28x6mm), with five pins
    Any info about the pinout/function/usage of these devices would be
    appreciated. Or point me to a more suitable group if i'm asking in the
    wrong place.
  2. Franc Zabkar
    Franc Zabkar Guest
    FWIW, I suspect that this may be a 64us PAL chroma delay line,
    possibly equivalent to a common DL701 or SLD145 or SDL145S.
    - Franc Zabkar
  3. dooj
    dooj Guest
    Thanks Franc, I'll take a look at those to see if they might compare
    or give a hint, i figured the delay line was a standard part of some
    TV circuit but i didn't know where to start.
