Identifying connector (power?)
Discussion in 'Datasheets, Manuals and Component Identification' started by toiletmirror, Jul 11, 2017.
  1. toiletmirror
    toiletmirror
    5
    Jul 11, 2017
    Hi uh, been fiddling around with an old blade server. See if I can connect it up to run outside the chassis which I don't have. Just an experiment.
    So I was wondering if this connector, which I assume receives power from the chassis, is something available off the shelves. Or if it's particularly customized for the blade & chassis connection.
    http://imgur.com/a/hQ7tu
    http://imgur.com/a/BBCe0
    Any idea? Thanks.
    P.S. Blade is Dell M600, chassis is Dell M1000e, if it helps.
  2. davenn
    davenn Moderator
    13,865
    1,956
    hi
    welcome to the forums :)
    haven't seen one of those before .... hopefully some one else can help
  3. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Knowing DELL it will be an in-house product and rarer than hen's teeth.
    The only reasonable source for one would be a redundant cabinet the blade came from.
    toiletmirror likes this.
  4. toiletmirror
    toiletmirror
    5
    Jul 11, 2017
    Oh. Does this happen to most Dell's products? What about HP? I do also happen to have a HP ProLiant blade lying around as well... haha.
  5. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Not easy to determine - many manufacturers re-badge their equipment for other distributors so there is sometimes cross-platform parts equivalence.
    Even if the connector were to be available after-market you can bet your life it would be at a cost you wouldn't want to pay!
    If you can't get the original housing but you want to still use the blade then hard wire the power connections.
