I'm working on a Total Power Europe power supply for a Gerber fast track 750 ploter. The PS mn is TPSF-135-4-A-ii. Its a no voltage output to any of the 4 dc volt terminals. The part I need help with is this resistor. I took a picture of it besde a similar on on the board so you could see the color difference. It looks to me to be, orange- white- silver- gold- black. Is this a ceramic axial resistor? When trying to decifer the color code, the silver or gray is throughing me off. What do you think the value may be. Can I use a different type of the same value to replace it. does the test seem out of range, if you can figure the value
http://i1374.photobucket.com/albums/ag408/genmar558/IMG_0424_zps7a427231.jpg
http://i1374.photobucket.com/albums/ag408/genmar558/IMG_0428_zpsb2a5512b.jpg
here is a different one that I have no trouble seeing the code to find the value, as you can see from the next pic, and it tests correct also.
http://i1374.photobucket.com/albums/ag408/genmar558/IMG_0426_zps19605ac6.jpg
http://i1374.photobucket.com/albums/ag408/genmar558/IMG_0427_zps899819ea.jpg
Thanks Mark
Thanks Mark
