Identification for onboard switch needed (Receiver Pioneer A-331)
Discussion in 'Electronic Repair' started by Jens Herrmann, Aug 6, 2013.
  1. Hello,
    the source selection on the front panel of the Pioneer A-331 has 6
    switches of which 4 are temporary switches (source) and 2 are permanent
    switches (tape monitor). They have stopped working properly and I was
    not able to fix the problem with contact spray this time. Now I want to
    replace them but cannot identify the brand and model.
    Take a look at
    http://img3.fotos-hochladen.net/uploads/pioneera331woivr6zn0p.jpg
    The footprint on the bottom side is a 2x6 dil -> 12 contact pins. Note
    that it is not possible to use a random model switch with the same
    footprint as there is a release mechanism which then would not work
    anymore. Thats why the blue knobs have the shape they have.
    Regards
    Jens
  2. Phil Allison
    Phil Allison Guest
    "Jens Herrmann"
    ** There is no sign of residue on the switches in the pic.
    So you used an evaporative contact spray like Freon or IPA.
    IME, usually only of short term benefit - if any at all.
    Try some WD40 or similar spray lubricant - seriously bet it makes all the
    switches work again.
    .... Phil
  3. Yes evaporative, but I had to open the switches to apply it.
    I would prefer to replace them as the switch mechanism inside did not
    look very well.
    Jens
  4. Phil Allison
    Phil Allison Guest
    "Jens Herrmann"
    ** Silly, risky thing to do.
    WD40 works in seconds with no disassembly.
    ** You have NOTHING to lose by TRYING my suggestion.
    Been working near miracles for me, nearly every day, for 40+ years.
    .... Phil
  5. N_Cook
    N_Cook Guest
    Even robbing a salvaged one is problematic as the plastic body of those
    sort of switches can only take the bare minimum of soldering heat before
    they start to deform. Can you wire in switches to somewhere that has
    more space and can take more conventional switches , assuming you cannot
    find an exact replacement. I've burrowed inside similar switches and I
    would say they are next to impossible to rebuild, even if you can safely
    get them apart with their sub-mm parts
  6. Tim Schwartz
    Tim Schwartz Guest
    Have you tried contacting Pioneer's parts department in your area?
    --Tim
  7. Phil Allison
    Phil Allison Guest
    "Rheilly Phoull"
    ** If a squirt of WD40 does not restore good operation - nothing else
    will.
    But be very careful with linear faders as it can dissolve the grease that
    gives them a nice feel - if possible, open them up and clean the track and
    wipers with a rag and small brush dipped in WD40.
    ** Nonsense.
    .... Phil
  8. N_Cook
    N_Cook Guest
    going by what looks like broken pcb in that photo, then likely
    mechanical damage to the switch, chemicals will not remedy that
  9. Kalyan Ram
    Kalyan Ram Guest
    ://www.web-design-hyderabad.in/seo-course-in-neredmet/
    Contact for advisor : +91 9177522892
    Web Design Hyderabad has a great demand and much more competition, But manyof companies are not able to provide good service for customers, The problem might be because of design quality, not providing dynamic works like contact form or may be client expecting more work with very low cost.
    To work with Web Design in Hyderabad, A designer should more honest with the client, you have to be explain the work of cost exactly, If not a designer will be struggled one day with client, Every one knows a designer can doany work but it takes time right, We have to cost as per our time
    web design companies in hyderabad
    Web design history
    The Hypertext concept was invented by Ted Nelson in 60s, however it was used only for some decades after. During 1992 to 1994 other developers startedadding up their own bits of HTML codes. HTML 1 tags and the HTML 2 born. As internet faster now the Web designers are putting more HTML capabilities.In 1995 more HTML tags have appeared and HTMl 3 was born. Now designers have an lot of option to use HTML B tables and style sheets and many more. They also have animated images, and Flash also introduced. It changed the whole landscape of web design from static to dynamic.
    The first web site published in the World Wide Web history at sometime in August of 1981. It was some 30 years ago, however the Internet born in the sixties. It wasn’t fast as today. However it was capable in transferring information from one computer to another. Tim Berners was the first person who invented the World Wide Web. Tim Berners is British computer scientist. The First website launched in year 1990. on December 25 1990 with the help of Robert Cailliau and young student at CERN, Tim Berners implemented firstsuccessful communication between a Hypertext Transfer Protocol (HTTP) patron and server via Internet.
  10. Phil Allison
    Phil Allison Guest
    "Jeff Liebermann= IDIOT "
    ** Wrong.
    ** Yawnnnn...
    ..... Phil
  11. Phil Allison
    Phil Allison Guest
    "dave"
    ** ROTFL !!
    It kills cockroaches too.
    ..... Phil
  12. Phil Allison
    Phil Allison Guest
    "dave"
    ** I have a small ( 75ml) can of Caig "DeOxit D100" in the workshop -
    bought it a few years ago for a price about 10 times that of WD40.
    Dammed if I can find a single job it is any good for.
    It has almost no penetrating ability and is a poor grease solvent.
    WOFTAM.
    .... Phil
  13. Geoff
    Geoff Guest
    What about CRC 5-56, how dya reckon it compares with WD-40?
  14. Phil Allison
    Phil Allison Guest
    "Geoff"
    ** You tell me - sunshine
    Almost 40 years ago, I used CRC 2-26 for the same jobs as WD40.
    ..... Phil
  15. Phil Allison
    Phil Allison Guest
    "dave the drongo "
    ** So WTF is it any good for ?
    ** I never use WD40 on electronics.
    Just mechanicals like pots, switches and connectors.
    Intermittents in ICs and other semis seem to be totally impervious to the
    stuff..........
    .... Phil
  16. **Dismantle the switches and clean with De-Oxitâ„¢.
  17. Phil Allison
    Phil Allison Guest
    "Trevor Wilson"
    ** Stupid, wrong advice.
    De-Oxit = Cramolin = snake oil.
    ..... Phil
  18. "Phil Allison" wrote in message
    ** De-Oxit = Cramolin = snake oil.
    You've obviously never used the stuff.
    I've been using it since the late '70s. The Red does a great job lifting the
    film from tin- and nickel-plated surfaces. The Gold does as nearly a good job
    on gold-plated surfaces.
    The 100% solution is not a lubricant. And I make no claims for its improving
    sound quality.
  19. **Try using the stuff sometime. It does what it is claimed to do.
    Naturally, the spray stuff is useless, but the type that you paint on,
    leave for a few minutes and wipe off works very well indeed. Switches I
    treated many years ago have long outlasted new replacements.
  20. Phil Allison
    Phil Allison Guest
    "William Sommerwanker Nut Case"
    ** Only nut cases use it.
    ** You've been a nut case much longer.
    ** Shame how it is fucking useless at fixing noisy pots and switches.
    ** The stuff does NOT do what WD40, CRC 2-26 and a host other similar
    fluids do in seconds.
    It is not a grease solvent, not a lubricant and does not penetrate small
    gaps and flow.
    .... Phil
