Sorry. I'm saying sorry in advance because I have already posted my views. Nonetheless, I have "refined" my paper of my ideas. This will be the last post, unless I create a working prototype of one of my inventions. ---------- Contents: (1) Inventions (2) Bird & Earth (3) Work (4) Electricity -\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\- -|-|-| (1) INVENTIONS -|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|- -/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/- Inventions: 1a) The "Wheel" Newton Motor 1b) The "Seesaw" Newton Motor 1c) The "Simple" Newton DC Motor 2a) The "Simple" Newton Engine 2b) The "Horseshoe" Newton Engine These five inventions work on Newton's law that "every action has an equal and opposite reaction." The idea is to harness the "action" and elimenate the "reaction", or convert the "reaction" into something useable. All inventions work without affecting the environment. That is, they don't need a road to push off of like cars, they don't have to push air like planes or spew out gases space shuttles. They propel themselves *internally*. That is, you can put a box around the entire device and the box would move, and nothing would enter or exit the box, and the device itself wouldn't react with the environment inside the box. (must be read using a "fixed-size font" to view diagrams) -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- =-=-=-1a) The "Wheel" Newton Motor=-=-=-=-=-=-=-=-=-=-=-= -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Side view: m -=- - | - | / \ | / \ <----- wheel with magnets \ | / installed on the outside / \ | / \ \|/ m|------------*-----------|m /|\ forward --> \ / | \ / / | \ \ / | \ / | - | - -=- ||||||M2 m M1|||||| <--- electromagnets (coils) ||||||M2 M1|||||| --------------------------- <---base The magnets "m" are connected to a wheel (which is connected to the base [connection not shown]), whereas the electromagnets "M1" and "M2" are fastened to the base. When one of the magnets "m" reach the bottom, an electric current is sent through both electromagnets, creating magnetic poles "M1" and "M2". "M1" should repel "m" while "M2" should attract "m". The force on the magnet "m" will cause the wheel to turn (in the diagram, that would be in a clockwise direction). Meanwhile, the forces on the electromagnets "M1" and "M2" will cause the base to move in the opposite direction (forward). Once the magnet "m" has moved sufficiently far away, the electromagnets "M1" and "M2" should turn off so that the next magnet "m" may come into position. So, the base will experience a force in one direction, creating useful propulsion, while the wheel can be hooked to a generator whose electrical output can be used to add more power to the electromagnets. Also, a motor may be needed to be connected to the wheel to start its rotation, or to maintain it. The electromagnets require a tremendous amount of current for a relatively short amount of time. Thus, capacitors are ideal. Note that the magnets "m" on the wheel could just as well be electromagnets. Here's a variation: One could put M1 and M2 onto an "outer" wheel which circles the "inner" wheel. The inner wheel would turn clockwise, as in the diagram, while the outer wheel would turn counterclockwise. Both wheels would be fed into generators. It would be interesting to see whether the output power from both generators matches (or surpasses) the input power of the two wheels. It's a long shot, but this could be a free-energy device. -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- =-=-=-1b) The "Seesaw" Newton Motor-=-=-=-=-=-=-=-=-=-=-= -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Top view: M1a---M2a m1 \ \ /\ \ || o <--seesaw || \ forward \ \ m2 M1b---M2b Ideally, "M1a", "M1b", "M2a", "M2b", "m1", "m2" are all electromagnets. "M1a", "M1b", "M2a", and "M2b" are fastened to the base, while "m1" and "m2" are connected to a "seesaw" whose pivot ("o") is connected to the base. When "M1a" and "m1" are nearly touching an electric current is sent through "M1a", "M1b", and "m1". "M1a" should repel "m1" while "M1b" should attract "m1". Thus, both "M1a" and "M1b" will experience a force in the forward direction, while the seesaw swings around bringing "m2" close to "M2a". As "M2a" and "m2" are close now, an electric current will pass through "M2a", "M2b", and "m2". "M2a" should repel "m2" while "M2b" should attract "m2". Again, "M2a" and "M2b" will experience a force in the forward direction while the seesaw swings back to its starting position to repeat the cycle. Thus, the base will experience forward propulsion as the seesaw continually swings about. If, as the seesaw swings, "m1" hits "M1b" or "m2" hits "M2b", then the collision will slow the forward motion. One could avoid this by keeping the back electromagnets far enough from the seesaw (as I have in the diagram), or a brake could be installed in the pivot to stop the complete swing of the seesaw. In may seem that if the seesaw swings so hard that "m1" hits "M1a" or "m2" hits "M2a" that the force of the collision will cause a forward movement. This is wrong. Only the momentum of the seesaw will "push" the base forward. However, when the seesaw hits the front electromagnets, the entire seesaw will "buckle" and the backward force of the electromagnet will be conveyed to the base through the pivot. One could avoid this by changing the seesaw by bending it so as to make a corner where it attaches with the pivot. Then, connect both ends of the seesaw together, ideally, the connection should be a curve. After doing that, the seesaw will undoubtly look more like a slice of pizza. One could also reduce the slice of pizza to simply an electromagnet fastened to a "line" which connects to the pivot. In that case, the pizza slice would look more like a mallet (one elctromagnet could be used in that case, instead of two). Again, the electromagnets require a tremendous amount of current for a relatively short amount of time. Thus, capacitors are ideal. Also, some the electromagnets can be changed into permanent magnets where it is fit. -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- =-=-=-1c) The "Simple" Newton DC Motor=-=-=-=-=-=-=-=-=-= -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Front view: --------- <-- wire wheel | | /-|\ /|-\ <-- frame (holds magnets) | |mmmmmmmmm| | | --------- | X forward _|--mmmmmmmmm--|_ <-- base (into paper) /\ ||__ magnets Side view: -- / \ <-- wire cylinder | OO | forward --> || \ || / || __||__ <-- base The Simple Newton DC Motor is similar to a regular "simple" DC motor except that there is only a portion of the wire exposed to a magnetic field. Thus the base experiences a forward movement, while the wire wheel experiences a circular motion (in the "side view", the wire wheel would move clockwise). The forward motion of the base can be used to propel the entire motor (and its load). And of course, the circular motion of the wheel can be harnessed to power a generator, whose electrical output can then be fed back into the motor. It should be noted that this Newton motor is inferior compared with the Wheel and Seesaw Newton motors, and with the Newton Engines (which follow). -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- =-=-=-2a) The "Simple" Newton Engine=-=-=-=-=-=-=-=-=-=-= -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- The Simple Newton Engine is simply a cylinder with a piston in it. The piston may require wheels to move inside the cylinder. STEP 1: \-----------\-----------\-----------\-----------\ The idea is to force the piston down the shaft, e.g. by using electromagnets or the explosion of gas. Side-view (cross-section): | ___cylinder | || | \/ |/------------- || #| forward --> |\------------- | /\ | ||__ piston ("#") | |<--start /-----------/-----------/-----------/-----------/ STEP 2: \-----------\-----------\-----------\-----------\ As the piston moves down the cylinder, the cylinder itself will accelerate and gain speed, and thus move forward. --> | ___ The cylinder moves "forward"... | || | \/ | /------------- | | # | | \------------- | /\ | ||__ ...as the piston moves "back" through the cylinder | <-- |<--start /-----------/-----------/-----------/-----------/ STEP 3: \-----------\-----------\-----------\-----------\ In fractions of a second, the piston will have arrived at the "back" of the cylinder. The piston must be stopped before it slams into the back of the cylinder, because if it does, then the energy of the piston will cancel out the "forward" velocity of the cylinder. So, the energy of the piston must be removed (by friction, e.g. brakes on the wheels) or harnessed (a method which converts the "negative" energy of the piston into something useable). | | | | /------------- | | # | | \------------- | /\ | ||__The piston must be stopped before it hits the "back" | |<--start /-----------/-----------/-----------/-----------/ STEP 4: \-----------\-----------\-----------\-----------\ When the piston has reached the end, and has been brought to a stop, it must be moved to the front of the cylinder, perhaps by hooking it to a chain which is being pulled by a motor. Perhaps, the piston can be removed from the cylinder when it is being transferred to the front, and thus leave the cylinder free so that another piston can "shoot" through it. | | | | /------------- | |# | | \------------- | | | |<--start /-----------/-----------/-----------/-----------/ Return to STEP 1: \-----------\-----------\-----------\-----------\ The piston has been returned to the front. Overall, the engine has moved and gained velocity. Now it is ready to restart at STEP 1. | | | | /------------- | | #| | \------------- | | | |<--start /-----------/-----------/-----------/-----------/ -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- =-=-=-2b) The "Horseshoe" Newton Engine-=-=-=-=-=-=-=-=-= -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- The Horseshoe Newton engine is like the Simple Newton engine, except that the chamber is a semi-circular loop. STEP 1: \-----------\-----------\-----------\-----------\ Again, the idea is to force the piston through the chamber, e.g. by using electromagnets or the explosion of gas. The piston should only experience a force when it is going opposite the forward direction; thus, the force on the chamber would be opposite that, that is, in the forward direction. Top view (cross-section): __ __ piston --> |##| | | ("##") | | | | | | | | <--chamber | | | | | | | | | \ / | /\ \ --____-- / || \_ _/ || --______-- forward start --> ----------------- /-----------/-----------/-----------/-----------/ STEP 2: \-----------\-----------\-----------\-----------\ As the piston moves through the chamber, the chamber itself will accelerate and gain speed, and thus move forward. __ __ /\ | | | | <-- The chamber || | | | | moves forward.. || | | | | ..as the | | | | piston --> |##| | | moves | \ / | through the \ --____-- / chamber. \_ _/ --______-- start --> ----------------- /-----------/-----------/-----------/-----------/ STEP 3: \-----------\-----------\-----------\-----------\ In fractions of a second, the piston will have arrived at the other side of the chamber. Unlike the Simple Newton engine, the piston does not have to be stopped from slamming into the chamber. Infact, when the piston slams into the end of the chamber, the chamber will be pushed forward. __ __ | | |##| <-- piston slamming | | | | into end of chamber | | | | | | | | | | | | | \ / | \ --____-- / \_ _/ --______-- start --> ----------------- /-----------/-----------/-----------/-----------/ Return to STEP 1: \-----------\-----------\-----------\-----------\ Also, note that the piston returns to a suitable position on its own, unlike the piston in the Simple Newton engine which needs to be "reloaded". Overall, the engine has moved and gained velocity. Now it is ready to restart at STEP 1 (from the other side). __ __ | | |##| <-- piston slamming | | | | into end of chamber | | | | | | | | | | | | | \ / | \ --____-- / \_ _/ --______-- start --> ----------------- /-----------/-----------/-----------/-----------/ It should be noted that both Newton Engines (especially the Simple one) create a small amount of force for a relatively minute amount of time. In my mind, they'd only be effective if many are used simultaneously. For example, I imagine that it wouldn't be too hard for either Newton engines to have a burst of 5N for a tenth of a second. Building a unit of ten thousand of such Newton engines would create a combined force of 5000N, assuming that the engines can "reload" in 0.9 seconds. However, if we can convert the Horseshoe Newton engine into an engine which is as quick as the the Internal Combustion engine, then it would create a large amount of force. The Internal Combustion engine has a cycle of four strokes: the intake stroke, the compression stroke, the combustion stroke, and the exhaust stroke. As the piston moves through the Horseshoe Newton engine, the combustion stroke for one part of the loop can be the compression or exhaust stroke for the other side of the loop. That leaves out two strokes which must be fit in somehow. -------------------------------------------------- Magnetic Propulsion for the Newton Engines: Cross-section: mmmmmmmmmmmmmmmmmmmm mmmmm ____ mmmmm <-- "m" are magnets mmmm /WWWWWW\ mmmm mmm /W/ \W\ mmm mm /W/ mm \W\ mm m W mmmm W m <-- "W" is a wire coil m |W| mmmmmm |W| m m |W| mmmmmm |W| m m W mmmm W m X forward mm \W\ mm /W/ mm (into paper) mmm \W\____/W/ mmm mmmm \WWWWWW/ mmmm mmmmm mmmmm mmmmmmmmmmmmmmmmmmmm If the magnets "m" are arranged such that the field is perpendicular to the wire, and if a current is set up in the wire coil, then the wire coil will either move forward or backward. This setup can be used in either of the Newton engines; the wire coil would be the "piston" and the magnets would be part of the "cylinder" or "chamber". The wire coil would need wheels on the side so that it could move about inside the cylinder or chamber. -\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\- -|-|-| (2) BIRD & EARTH -|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|- -/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/- Consider an Earth that is stationary and is not affected by any external forces. Alone on the Earth is a hummingbird sitting in its nest in the world's last tree. The rest of the Earth is totally lifeless and motionless. Suddenly, the hummingbird, which has a mass of 5 grams, begins to hover 5 kilometers off the ground. The downward gravitational force on the hummingbird is given by the equation F = G*m_b*m_e / (r+5)² where G is the gravitatiional constant (6.673 * 10^(-11) Nm²/kg²) m_b is the mass of the bird (0.005 kg) m_e is the mass of the Earth (5.97 * 10^24 kg) r is the radius of the Earth (6.38 * 10^6 m) Now, this hummingbird is resilient and has enough energy to hover above the ground for 10^19 years. It is obvious that the hummingbird is converting chemical energy into kinetic energy. As it flaps its wings, two things happen; one, the hummingbird is pushed upward, and two, air is pushed downward. Since the hummingbird is a fair enough distance from the Earth (5km to be exact), the downward force on the air molecules never actually reach the ground because it gets distributed amongst other air particles. And so, as this force is distributed amongst billions of molecules, none of them ever gain a sufficient velocity to reach the ground, and so the force isn't conveyed to the ground. So, we took care of all the forces, right? Wrong! We only considered the gravitational force of the Earth on the bird. But what about the gravitational force of the bird on the Earth? That force creates an acceleration of a = G*m_b / (r+5)² = 8.196889698 * 10^(-27) meters/second² After 10^18 years, when the hummingbird returns to its nest, the Earth will be traveling at a velocity of t = 10^19 years = 3.15576 * 10^26 seconds v = a * t = 2.586741663 meters/second The Earth was stationary and now it's moving at more than two meters per second! Can you account for that? Where did the energy to move the Earth come from? Some of you may argue that the bird's chemical energy was converted to the Earth's kinetic energy. That's quite ridiculous because, as we saw earlier, the chemical energy of the bird was transferred to kinetic energy of its wings and then of air particles; in simpler terms, the bird's energy simply pushed air, nothing more. I hope you can clearly see and appreciate that gravity (and other forces) create kinetic energy instantaneously out of nothing. But notice that at any "instance", the instantaneous energy "cancles out". You see, as the bird was hovering, we could say that the bird was perpetually falling to the Earth. Likewise, the Earth was perpetually falling toward the hummingbird. The forces on each (bird and Earth) when taken together, cancel out. However, when that instantaneous force is sustained for a real duration of time, it effects its environment by adding or removing energy from the system. In this case, energy was added to the system; that's why the Earth is moving. What does all of this mean? It means that the law of conservation of energy is wrong! It means that perpetual motion and free-energy devices do not contradict reality! -\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\- -|-|-| (3) WORK -|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|- -/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/- 20 joules equals 20 joules, right? Well, consider the following: "Ball A" work done = 20 joules force = 10 Newtons mass = 10 kg acceleration = 1 m/s² change in distance = 2 m initial velocity = 0 m/s final velocity = 2 m/s change in time = 2 s "Ball B" work done = 20 joules force = 10 Newtons mass = 0.1 kg acceleration = 100 m/s² change in distance = 2 m initial velocity = 0 m/s final velocity = 20 m/s change in time = 2/10 s Each ball experienced the same force over the same distance. Each ball had the same amount of work done on it. But, Ball A experienced a force of 10 newtons for 2 seconds, while Ball B experienced the same force for only 2 tenths of a second. However, if you agree that the same amount of work was done on each ball, then we can say that "10 newtons held for 2 seconds can give the same result as 10 newtons held for 2/10 of a second!" Intuitively speaking, that's ridiculous! If you cannot see the intuitive error present here, then the following analogy may help you. Consider two classmates, Jack and Jill, both able to hold a one kilogram brick. Naturally, holding that brick on Earth is approximately equivalent to maintaining a force of 10 Newtons. Let's say that Jack held his brick for 20 seconds, and Jill held her brick for 2 seconds. Now, without using any scientific jargon, who did the most work? If you try to answer that question in plain English, then I'm sure you will see the intuitive error presented above. (Even if you were to replace Jack and Jill with two tables, and rested the bricks on the tables, work is still being done, as I mention below.) This leaves the Joule system for work in a bit of a muddle, and I fully agree that I'm not exactly sure how to explain this short-coming, even though I'm sure I have the start. We saw from the analogy that, in plain English, Jack did more work than Jill. Thus, work should be (intuitively speaking) proportional to force and a duration of time. Using Occam's Razor, the simplest equation we can make using work, force and time is "W=Ft". Notice, that this means that work done on an object does not neccesarily have to create motion by increasing velocity. On the contrary, even if you placed a book on a table, work is being done; the table is "maintaining" a force, and likewise, the book is "maintaining" a force. The work of gravity between the two is causing "stress" at the atomic level. Work, in general, does not require an increase/decrease in velocity. Thus, I call "W=Ft" the equation of "general" work. However, let us consider "effective" work, a word I coined to mean work that increases velocity unhindered by other forces. We will see below that, effective work is really just general work which is allowed to create motion, unhindered. Force equals mass multiplied by acceleration. Intuitively speaking, it is obvious that force should be proportional to mass and to acceleration. However, why isn't there a "coefficient"? And why not "mass squared" or "acceleration cubed"? The equation is how it is because of two things; one, intuitively, it makes sense not to add extra "factors" (Occam's Razor), and two, it simply gives the "right answers". Now, let's examine the equation for work as it stands today, that is "W=½mv²". Intuitively speaking, "effective" work should be proportional to mass and to velocity. However, we added "factors" to the equation. Without using scientific or mathematical jargon, I say that we should be able to explain, in plain English, why we added factors to the equation. And if we can't, then by Occam's Razor, we should remove those factors. And, if we do remove all the extra factors, and say that the equation for effective work is "W=mv", then we have again arrived at the equivalent general equation for work, "W=Ft". The equation "W=½mv²" seems to work, but does it really? Consider dropping a brick from the height of one meter above the ground. Let go, and the brick falls. Now, it is said that when you lift the brick up to one meter, you have given the brick a "potential energy". But let's consider two scenarios, Jack and Jill, each lifting the brick from the ground to one meter above the Earth. Jack lifts it in 20 seconds while Jill lifts it in 2 seconds. True, the outcome is the same for either participant. However, in plain English, Jack did more work; he did the same amount of "useful" work, but he did a whole lot of "useless" work by taking his time. Now, work defined as it is today is wrong intuitively, but nonetheless, it is a *VERY* *USEFUL* "measuring tool", and it *WORKS* with the non-intuitive equation "W=½mv²". That is, it calculates "useful" work, but not "useless" work. But intuitively, work should encompass both "useful" and "useless" work. I know that what I call work is called momentum and so I assert that work and momentum should be equivalent and synonymous. And I propose that the real unit for work (that is, force multiplied by time) should be "P", for Prescott, Joule's middle name. Thus, one prescott equals one newton second. I relegate the old, traditional meaning for work to the term "typical useful work" or just "typical work". If we allow work to equal mass multiplied by velocity then we can say that force and work are both forms of energy, but they are apparent in different "time frames". That is, work requires a duration of real time for an effect to be experienced, while force requires an infinitesimal amount of time to have an effect experienced. The law of conservation of energy is wrong! There are two reasons for this: 1) The Joule system is wrong (it only encompasses "useful" work) 2) Attributing potential energy to objects is usually wrong "Potential energy" should only be called that so long as the potential cannot disappear without being realized. Consider a balloon of hydrogen a meter above the ground. The hydrogen has a mass of M. Now, if we cause all the hydrogen to undergo fusion, then we'd be left with a balloon full of helium and a whole lot of energy. The mass of the helium would be approximately 0.992*M. There's a drop in mass. But gravitational potential energy is proportional to mass. So, where did that minute, but measurable, amount of potential energy go?!? It got turned into various forms of energy, e.g. heat, light, sound. Do these forms of energy have a gravitational potential energy? I don't think so; sound definitely doesn't. So where did that gravitational potential energy go?!? I don't know. There's definitely less. So, either we say that potential energy was destroyed without being realized (quite ridiculous), or we say that the hydrogen balloon never truly had a "potential". (I'd go with the second one.) In reality, energy is being created all around us instantaneously. (I have never seen it be destroyed instantaneously.) When energy is created instantaneously, its immediate affect on the system is nothing (e.g. for forces, the vectors cancel each other out). After the immediate effect, and after a minute amount of real time, this instantaneous energy will be found to have either done "positive work" on the system or "negative work"; that is, energy will be added to the system, or removed. Should this instanteous energy be sustained for a longer duration of real time, then the energy might be found to have not added or removed any energy from the system (that is, it added the same amount of energy that was removed). -\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\- -|-|-| (4) ELECTRICITY |-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|-|- -/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/- Now, I am going to apply work using prescotts on an electrical circuit. *************************** Let's find the average drift velocity: ------------------------- A is the average (weighted with respect to L) cross-section of the wire (m²) n is "free" electrons per unit volume (electrons/m³) e is the magnitude of charge of an electron (1.602 * 10^19 C/electron) v is the average drift velocity of the electrons (m/s) I is the current in the (C/s) dq is an infinitesmal amount of charge (C) dt is an infinitesmal amount of time (s) dN is an infinitesmal number of electrons (electrons) ------------------------- (1) dq = e*dN dN = nAv*dt (2) dt = dN/(nAv) (1)/(2) dq/dt = e*dN/(dN/nAv) I = enAv v = I/(enA) *************************** Let's find force: ------------------------- W_j is the Work in Joules (N*m) f is the force (N) s is the distance (m) V is volts (N*m/C) ------------------------- W_j = F*s dW_j = F*v*dt dW_j/dt = F*v V*I = F*v V*I F = ----- v = VenA ------------------------- P is pressure (Pa) ------------------------- So, F V = --- enA P = -- en We can now omit the use of joules in the description of volts. We can say that "Voltage is the electromagnetic-pressure (created by an EMF source) per density of charge." Notice that the pressure supplied by an EMF has nothing to do with the length of the circuit. A battery hooked to a 1 meter circuit of 1cm² wire uses the same pressure to start a current as a similar battery hooked to a 10000 meter circuit of similar wire! *************************** ------------------------- W_i is the Initial Work (in Prescotts) (N*s) (the work done to start the electrical circuit) t is a duration of time (s) ------------------------- W_i = F*t = VenA*t *************************** ------------------------- U is Initial Work (in Prescotts) per Coulomb (N*s/C) Q is an amount of charge (C) p is the resistivity of the wire (ohms) l is the length of the wire (m) ------------------------- U = W_i/Q = F/I = (VenA)/(V/R) = enAR = enA*(p*l/A) = enpl Now, "U" is a constant for any given circuit. So, given any circuit, a constant amount of work is done to move a Coulomb along the circuit. Makes sense that it doesn't vary.. *************************** ------------------------- µ is Initial Work (in Prescotts) per Coulomb meter (N*s/(C*m)) ------------------------- µ = dU/dl = enp Thus, the rate at which work is done per unit distance depends only on the material. Makes sense.. *************************** ------------------------- t_c is the average change in time between electron collisions (s) m_e is the mass of an electron (9.109 * 10^(-31) kg/electron) ------------------------- Each electron gains "m_e*2v" of energy (remember, we are using prescotts) before it makes a collision and losses it's energy. The collision will take place in "t_c" seconds. "U" is the amount of work to move a Coulomb "l" meters. Thus, in "l" meters, there will be "l/(v*t_c)" number of collisions. So, l m_e*2v ----- * ------ = U v*t_c e 2*l*m_e --------- = enpl t_c*e 2m_e t_c = ---- e²np which is correct. *************************** ------------------------- W_t is the Total Work (in Prescotts) (N*s) (the total amount of work done by all the electrons) l_c is the average length between electron collisions (m) a is acceleration (m/s²) ------------------------- F a = ----- m_e ------------------------------------------ v = a * t_c F v = ----- * t_c m_e ------------------------------------------ l_c = 2*v*t_c 2F = ----- * (t_c)² m_e ------------------------------------------ W_t = F * (l/l_c) * t l = F * -------------- * t 2F ----- * (t_c)² m_e m_e = ---------- * l * t (2m_e)² 2(----) (e²np) m_e = ----------- * l * t 8(m_e)² --------- e^4n²p² e^4n²p² = --------- * l * t 8m_e ------------------------------------------ Even though the pressure by a source on two different circuits which use the same wire is the same, it's obvious that more *work* is being done in a longer circuit. The reason why the force/pressure is the same while the work isn't is not hard to understand. An EMF source creates "electromagnetic pressure" on the anode and/or cathode. Once a circuit is started, this electromagnetic pressure is felt throughout the circuit. You can imagine the electrons as being dominoes. Whether you have 1 meter of dominoes falling or 10000 meters of dominoes falling, the initial force to topple the first domino may be the same, and yet, the amount of work done (the number of fallen dominoes) can be very different. This obviously means that energy *isn't* conserved. That's right. -\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\-\- -/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/-/- P.S. Two masses (e.g. stars) with sufficient velocities can pass by each other without colliding and both gain speed. (As I said above, gravity can create energy.) I believe that that might be the cause for the seeming acceleration of the expansion of the universe, not "dark energy". Just a guess.. by Raheman Velji, unfortunately known as the devil.
That would be a good idea. Let us know when it works. And not a moment before. Calculate how many calories are being expended by the bird. And then answer where he got the energy from. Then you'll know where the energy to move the Earth came from. The bird is not "just moving air". He is expending enough energy to keep himself hovering at 5m. When he runs out of energy his distance from the earth will be zero. -CF
that works too... the Wow was mainly aimed at the idea someone would sit down and type all that crap up...... and for what.....
You know what, its part of the learning process. If the OP is 13 I'd say theyre doing well to have a go and investigate their ideas. To learn any subject properly youve got to ask the questions, including the ones that others know the answers to. What is wrong is the popular learning process which discourages this, thus killing enthusiasm and confidence. Also the misperception of learning. If OTOH the OP has been posting these supposed inventions for the last 15 years, snore. If theyre learning about physics for the first time, and have just come up with these ideas, good. If so, listen to the feedback, and use the greater knowledge thus gained in your next design. I reinvented the bridge rectifier, and it taught me that I can come up with ideas, tackle and solve problems, and that some of them even work. Thats a good thing to learn. The first 2 ideas are known motor mechanisms, the rotary one being fairly similar to popular dc motors today, except that the rotor and stator are swapped round, ie the magnets are round the outside with the coils on the rotor. The commutator is used to switch the coils on and off. The others wont work too good. Friction between 2 objects means that each object exerts force on the other one. The end result is the same, just that with friction present they dont adjust their speeds instantly, but take a little time. There really is no action without reaction. When the flying bird beats its wings 5 miles up it pushes the nearby air molecules which push more air molecules which eventually push the earth - the difference with great height is that the push on earth is spread out over a very large area, and is thus so small you wouldnt notice it. And - everyone comes up with this one - when you feed energy round a loop all that happens is you lose some of it at each conversion process. The motor isnt 100% efficient, the generator isnt either. 101% efficient processes are very hard to come by. Regards, NT
if he is 13yrs old or however old... it doesn't matter... i give him credit for learning if that is what he is doing. I guess the whole thing sounded alot like Fracture mechanics in the point of view of A.A. Griffith.. which as engineers we have to learn for our FE exams.... in short his assumptions jumps back and forth between brittle and ductile materials which are completly opposite in the study of fracture. Which is kind of retarded. I took Rahemans ideas as someone who is trying to redefine some of the basic laws of physics that have been held true for ages. If he is out to learn I mean no disrespect and hope he continues to learn.
Check this out: http://www.usenet.com/newsgroups/misc.creativity/msg00742.html Complete with the Jack and Jill and bricks story. Here's a whole passel of them. http://www.google.com/search?q=raheman+magnets&hl=en&lr=&ie=UTF-8&oe=UTF-8&filter=0 Whether this is a crackpot or a junior crackpot doesn't influence me in the least. He's spewing crap all over usenet, and I won't call it a silk purse because PERHAPS he's young.
hahaa...... then i stick with my first couple statements... way too much time on his hands... gotta love the internet
We all write crap on usenet. Those that never put a foot wrong dont post anything. Talking crap is not itself the problem. And age has nothing to do with it either. It depends what else is going on, and that we dont know. My first reaction was also 'what is this ----', but then I stopped. I've posted a lot more than one posts worth of non-runner ideas myself, and must have written 100 for every one I show someone. The brain is a production line, and like any production line it produces useful goods and crap, both. And to learn one has to clear out the crap, debunk the errors, learn the subject. That, per se, is not the problem, its the solution. It is also what we spend a fair bit of our time on this ng and others discussing. IMHO it only gets to be a bad thing when someone gets stuck in a senseless rut, and generally wastes everyones time with repetitive bullshit. makes me wonder where this OP was at with this one - who knows. OP? Regards, NT
For the most part, agreed. I found a track record of reptitive bullshit. "Who knows"? It isn't usually important enough to chase in depth. If he's true to his word that he'll quit till he can actually demonstrate what he's talking about then there's no problem, case closed.
