Jamie Morken
I came up with an idea to generate electricity from ocean waves, and
was wondering how it compares to other methods. Basically there is a
heavy floating vessel riding the wave, and a steel rod attached to it
going down to the seafloor. At the seafloor there is a vertical
hydraulic cylinder with a length equal to the ocean wave amplitude. The
steel rod is connected to the piston of the hydraulic cylinder, and the
up and down action of the waves run a rotary hydraulic motor using the
up down action of the piston. This hydraulic motor shaft is attached to
an electrical generator. There are a couple more details too like a rod
guide above the cylinder to keep the piston aligned, and a concrete base
around the cylinder to make the devices deployable by ship.
Also since this is an electronics newsgroup, here's an electrical
analogy: the waves are the voltage signal and the seafloor is the
circuit ground, and the load is the hydraulic fluid movement Higher
voltages (wave amplitude) equals more power!
cheers,
Jamie
cheers,
Jamie
