K
kalalau73
A surface mount capacitor got knocked off my favorite 486 motherboard. I
want to try to fix it, if possible. I would rather not throw away the board
cause I like 486s. I've searched on at least 100 old boards to find one of
these chips. A few times I've found chips with similar markings, but
different size and numbers.
The broken component is a tiny grey-black rectangle about 3/16 x 1/8 x 1/16
inch with one lead on each end. One end of the of the chip has a white line
printed along it ( I assume that this signals the + end of the chip
corresponding to that marking on the motherboard). The chip has the
following markings:
10 - 25
F1 2
The 2 has a circle around it. The chip is labeled on the motherboard as
TC2 (One of four identical ). It is right next to the AT power connector.
With the chip missing off the board, the board is totally dead.
I finally found a similar chip on an old modem, the same size, but it has D3
in place of F1 (all other markings are the same).
My questions: What kind of chip is it? Is there a source to replace it? Is
there a discrete component I can substitute? Can I substitute the D3 chip?
There are some other TCx components on the board that look similar but are
tan-orange color with brown printing that says 10u 16 (could be 10 micro
farad capacitors?). There are some smaller BCx, Cx and Rx components also.
Could be 3-4 different types of capacitors: TCx (two colors), BCx, Cx ??
Thank you, I would appreciate any help.
following markings:
10 - 25
F1 2
