G
[email protected]
I'm working on a little fanspeed regulator circuit. This specified
debouncing circuit wasn't working at all (bad switch?), so I
substituted a design known to work that used a not-gate (LS04). It
warks fine, but the problem is that the LS04 chip heats up pretty
quickly, then eventually gets too hot to leave it plugged in. I
searched the layout, and checked all the connections, but couldn't
find any shorts or bad connections. I had a different chip before (I
think a display driver) that was set up propperly on a breadboard but
burned up too, leading be to believe that it was just a bad chip. So
its possible that the chip I have (04) is just bad, and may have been
damaged during soldering. Does this theory fly with any body else?
Is there anyhing I can do to fix it without using another chip? Ground
outputs, etc? Has anybody had a 'bad' chip that burns up right out of
the box? Does the idea of soldering sound like a cause of overheating?
Cheers.
Cheers.
