IC for Power meter AC and DC
Discussion in 'Electronic Design' started by maxi, Mar 20, 2006.
  1. maxi
    maxi Guest
    is it there a chip for build a power meter for AC and DC at the same
    time?
    For the AC mesure it should give the power for system at 50 Hz or 16
    2/3 Hz.
    Thanks for any help.
    Bye,
    MAX
  2. Power (AC or DC) is just the instantaneous product of volts and amps,
    so you can do this with a microcontroller or a DSP given appropriate
    transducers, depending on the detailed requirements. There are some
    ICs optimized for 50/60Hz energy measurement that may or may not be
    applicable (in conjunction with a lower end microcontroller). Eg.
    Crystal, AD. Energy is just the integral over time of power, of
    course. What's the 16.66Hz power used for? A diesel-electric
    locomotive?
    Best regards,
    Spehro Pefhany
  3. You're almost right. 16+2/3 Hz is used as railway
    supplying frequency in central europe. At the time
    of its intorduction, the semiconductors for DC were
    not available and 50Hz was considered being too lossy.
    So they took generators with a 3rd of the number
    of poles.
    Italy is having 3000VDC, but north of it, it
    is 16+2/3 Hz (15kV, possibly).
    Rene
  4. Mac
    Mac Guest
    What do you mean by power meter? Power delivered to a load? How is the
    meter hooked up?
    Or should the power meter also be the load (like an RF power meter)? If
    so, what do you want the impedance of the load to be?
    What kind of Voltage and power ranges do you expect to see?
    Or maybe you just want to measure Voltage?
    --Mac
  5. maxi
    maxi Guest
    yes 16 2/3 Hertz is for Traction and Auxiliary converter on
    train............from 1500V to 25000V.
    I need mesure the power delivered to load.
    I put a Tension trasductor(TV) and a current trasductor(TA) and i
    reduce the tension to few mV (both TV and TA).
    Then i need to multiplier V*A for reading the power.
    I know the AD632 but i dont know if this component can give the rigth
    value if I and V have a COS-Fi differente to = as DC.
    Bye
    MAX
  6. STPM01 from STM is one of many available.
    Many thanks,
    Don Lancaster voice phone: (928)428-4073
    Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
    rss: http://www.tinaja.com/whtnu.xml email:
    Please visit my GURU's LAIR web site at http://www.tinaja.com
Similar Threads
Loading...
