in my perspective, the resistor limits the current that flows through the switch.......without the resistor, closing the switch would cause a short circuit that could damage the power supply of the circuit and would cause all the current that flows through the circuit to flow through the short (NOTE: current takes the path of least resistance)
also, when the switch is closed, the voltage across the reset pin is zero, since there is a wire across it (NOTE: the voltage across an ideal wire is zero).......this causes the reset pin to be low (less than 0.7V)
hope this helps........
