Latch = flip flop in electronics?
Latch can mean one of several things.
It can mean to remain in one state once triggered (as in an SCR remains conducting once triggered until current through it falls to zero)
It can mean that something get stuck in an invalid state, as in the circuit latched up (this is a similar meaning to above but refers to a generally unplanned or undesired fault condition).
It can refer to a functional component which remembers the state of some (almost invariably logic) signal even after that signal changes. Note that this function is equivalent to memory in that a certain value can be "stored" in it.
It is the last of these which most closely corresponds to a flip-flop.
These circuits are clearly bistable in that they can remember a 1 or a 0 and will retain the state indefinitely (or more frequently while power is applied).
The simplest types of memory (at least the simplest to understand) are a type of flip-flop. However there are many different types of bistable flip-flops. SR (most similar to what is in the 555), JK, D, and T. All but the SR are clocked (meaning that another signal is required to cause them to act on their inputs.
A D flip-flop is the typical latch, where the Q output follows the D input on the application of a clock pulse.
D flipflops are essentially static RAM.
Dynamic RAM (which is also a sort of latch) records the state on a capacitor and reads this value when required. This is essentially an analog storage mechanism and must be refreshed periodically to ensure that the voltage on the capacitor remains valid. This circuit bears little relationship with a flip-flop, yet performs in some respects a very similar function.
Going back into the past, memory used to be stored on small magnetic rings (cores) and in these the magnetic field was indeed flipped from one direction to the other to latch a value. In a bizarre twist, reading the value destroys it, so you have to write after read.
So yes, while a latch may be a flip-flop, it may be a very different type of flip-flop, or it may be something entirely different.
