Sir . . . . . .Areyoustillonthatold-old-old-oldphone?
It looks this may do the trick. http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=184438686&uq=635838260667837185
Yep, that's them, and also a STOCKING dealership, and even an option of the Kemet brand.(Spel chek sez Emmett, but we knows that he got caught in the "downsizing" back in '91 ! )
I'm curious though Does it sound plausible that I squashed it with the wire?
I certainly don't think so, the insulation on the wire should give some cushioning, even in a cramped positioning.
Is it likely something else could be wrong with the device?
How successfull was your battery replacement, and did it seem to give you some normal use and performance BEFORE this mishap occurred ?
I didn't look it up, but the unit does use a single 3.6 VDC Li Ion cell of ???? current/wattage , doesn't it ?
I would initially want to know if this is YOUR unit and you have been using it for Y-e-a-r-s , with never any problems, and if the charger is the original manufacturers unit and has never given you a-n-y problems either.
Now if you have used an out of a blister pack, generic power unit , AND NOT WELL voltage limited, that would be another story.
That family of dry tantalum electrolytics like to fail in the manner that you have found, when being subjected to voltage overload.
IF there is adequate current / power reserve in the power supply / battery, they will make a distinctive snapping / cracking noise and a putrid, yet VERY distinctive odor, will emanate forthwith !
PLUS . . . . they can initially glow in the dark, they get so hot.
EDIT: Should I replace both? It looks like they are a pair of some sort in the picture.
SURE looks like the pair are paralleled , with them being mounted side by side, like they are.
Testee . . . . .testee . . . .
Initially switch your VOM to DC mode and check for any voltage presence between the +'s of the electrolytic pair and then do the same between the -'s.
That initial test THEN gives a safe go-ahead to switch the VOM to its low ohms range and then check between the +'s for an expected "short" (interconnecting foil pad ) and then test
the -'s in the came manner.
Remember . . . . .
Your VOM knows all . . .sees all . . .and tells all . . . . and is easily 10 orders of magnitude better than an Ouija board !
73's de Edd
