I2C slave
Discussion in 'Electronic Design' started by [email protected], May 10, 2005.
  1. Guest
    Hi all,
    This is regarding I2C slave, how can i switch between a recive and a
    transmit pahse.
    Thanks in advance,
    praveen
  2. Bob Stephens
    Bob Stephens Guest
    If I understand your question, in I2C the Master initiates all
    transmissions, send and receive. The slave must respond to the Master, so
    your slave's interrupt service routine ( or whatever) needs to check for a
    read or write flag on reception of a start command from the Master. On the
    SMBus, there can also be multiple Masters - not sure if I2C supports this
    or not.
  3. John Fields
    John Fields Guest
  4. Pooh Bear
    Pooh Bear Guest
    The slave responds to the master initiating a read or write cycle - i.e
    the master either tells the slave it's going to be sent data or requests
    the slave to send data to the master.
    You seem to be having a lot of trouble understanding I2C !
    Graham
