I2C programming ?
Discussion in 'Microcontrollers, Programming and IoT' started by vead, Apr 10, 2015.
  1. vead
    vead
    473
    14
    Nov 27, 2011
    Hello ,
    I need help to understand I2C programming for Microcontroller.
    1. Initializing I2C
    2. start I2C
    3. stop I2C
    4.ACK for I2C
    5. NAK for I2C
    I am writing function one bye one. if there is any mistake. let me know
    1. Initializing I2C
    Code:
    void I2C_Init()
        SDA = 1;
        SCL = 1;
    2. start I2C
    Code:
    void I2C_Start()
        SDA = 0;
        SCL = 0;
    3. stop I2C
    Code:
    void I2C_Stop()
        SCL = 0;
        SDA = 0;
        SCL = 1;
        SDA = 1;
    4.ACK for I2C
    Code:
    void I2C_Ack()
        SDA = 0;
        SCL = 1;
        SCL = 0;
        SDA = 1;
    5. NAK for I2C
    Code:
    void I2C_Nak()
        SDA = 1;
        SCL = 1;
        SCL = 0;
        SDA = 1;
    If above all points are correct then I want to write another function, so please tell me if there are any mistake ?
  2. vead
    vead
    473
    14
    Nov 27, 2011
    actually I am interfacing RTC with microcontroller and LED.
    actually I have prototyping KIt (cortex m0). I only need c code.
    I want to control LED using real time clock via I2c pins
    Set alarm for 5 second (automatically turn on LED for 5 second )
    Set alarm for 3 minute (automatically turn on LED for 3 minute)
    Set alarm for 1 hours (automatically turn on Led for 1 hours )
    SCL connected with P3.5;
    SDA connected with P3.1;
    LED connected with P1.6
    I did google search and I am trying to write some code myself
    Code:
            void I2C_Init()         //
                SDA = 1;
                SCL = 1;
            void I2C_Start()       // start I2C
                SDA = 0;
                SCL = 0;
            I2C_write()               //  send data to Ds1307
            I2C_write(0xD0);      // address of the DS1307 )
            I2C_write(0x00);      // address of seconds register
            I2C_write(0x10);       // 10 data as 10 second
            void I2C_Ack()
                SDA = 0;
                SCL = 1;
                SCL = 0;
                SDA = 1;
            void I2C_Stop()    // stop I2C
                SCL = 0;
                SDA = 0;
                SCL = 1;
                SDA = 1;
            void I2C_Start()
                SDA = 0;
                SCL = 0;
            I2C_read()
            I2C_write(0xD1);      // address of the DS1307 )
            void I2C_Nak()
                SDA = 1;
                SCL = 1;
                SCL = 0;
                SDA = 1;
                SCL = 0;
                SDA = 0;
                SCL = 1;
                SDA = 1;
    I don't understand how to set alarm for second , minutes and hours ?
  3. JWHassler
    JWHassler
    81
    17
    Dec 22, 2014
    There are a few problems here.
    1. The section of code "I2C_write()" is recursive, (calls itself) and that's not usually helpful.
    2 "I2C_write()" also sends a parameter to a function that does not use one.
    3. ... or maybe it does: there are no prototype-declarations shown
    4 "I2C_read()" returns nothing: in other words does not read. I don't think that's what you want
    If you have a dev-kit for your micro-controller, you should have some sample-code to use. There's no shame in doing so, and you will get going much faster
    Arouse1973 likes this.
