I2C on PSoC 5LP
Discussion in 'Microcontrollers, Programming and IoT' started by megawarp, Jan 22, 2018.
  1. megawarp
    megawarp
    Jan 22, 2018
    Hello everybody,
    I'm trying to realize a bridge I2C - SPI with a board that carries a PSoC 5LP. The board receives I2C packets from another board with Linux inside (commands like i2cset and i2cget) and converts them to SPI format towards a board with a camera sensor. The first board is a I2C master and the sensor is an SPI slave, so the PSoC implements an I2C slave and an SPI master.
    The problem I am facing with is that I don't understand how to correctly detect, in the PSoC, that I have received a get or a a set instruction. It doesn't seem to exist any interrupt callback that signal that event; there are some flags, though, that are set in a odd way and, it seems, not constant sequence. Due to this behaviour and because I check these status flags to detect the sets and gets, sometimes after a get instruction (correctly detected) it also catch a get instruction, thus performing an undesidered write on SPI.
    The pseudo code is the following:
    while(1)
    if(write status flags are set)
    do spi write
    else if(read status flags are set)
    do spi read
    copy data to i2c buffer
    Does anyone know how to correctly detect the i2c packets? I'm using PSoC Creator 4.1 as IDE.
    Thank you
  2. megawarp
    megawarp
    Jan 22, 2018
    I have found a workaround though not finding, I think, how that software object (I2C Slave) is meant to be used.
    I alredy performed a poll checking the status flags but there was the problem I specified in my previous post.
    The workaround is to add a futher check to detect the incoming write command using the buffer size functions.
    There are two functions indeed, one for the read buffer and one for the write buffer. Currently I check that SlaveGetReadBufSize returns zero because if it receives something but the read buffer is empty it must have been a write command.
