I2C hangup
Discussion in 'Electronic Design' started by Richard Henry, Jun 30, 2005.
  1. I have noticed while checking out a prototype board that the I2C devices
    occasionally hang the bus (SDA held low) preventing any further bus
    transactions. My only fix is to cycle power to the board. That leads me to
    wonder whether adding a fet power switch feeding the I2C devices controlled
    by the micro might be of benefit - when the micro detects a hung bus, it can
    "reset" the I2C devices.
    Anyone ever have to do this?
  2. Joel Kolstad
    Joel Kolstad Guest
    Not personally, but you'll find some application notes on Phillip's web site
    where they discuss the problem and propose various solutions. They make "bus
    splitter" ICs that can be used to isolate "hung" portions of the bus, generate
    error signals that can be used to reset processors, etc.
    Part of the trick, though, is deciding how long SDA should be able to camp low
    before you decide the bus is hung. I've heard of people sometimes using SDA
    as a form of handshaking and allowing up to ten seconds before they time out
    the bus!
    ---Joel
  3. John  Larkin
    John Larkin Guest
    Not me; I always use SPI.
    John
  4. At last, a friend.........................................
    martin
  5. Piotr Piatek
    Piotr Piatek Guest
    Following solution is recommended by Atmel in the AT24C01 memory
    datasheet:
    MEMORY RESET: After an interruption in protocol, power loss or system
    reset, any 2-wire part can be reset by following these steps:
    1. Clock up to 9 cycles.
    2. Look for SDA high in each cycle while SCL is high.
    3. Create a start condition.
    Perhaps this would help.
    Best regards
    Piotr
  6. PeteS
    PeteS Guest
    I mentioned this problem in a thread on hot swap systems. I've done
    systems with dozens of I2C endpoints, and the solution was to use a
    SMBus controller.
    I2C is specified to DC, whereas SMBus (same bus protocol) is not, and
    therefore implements a timeout. Note that provided the bus master
    implements the SMBus timeout, you'll be ok. It gets more complicated if
    you have multiple masters, but the principle is the same.
    I never use pure I2C now simply because of this issue. Most processors
    with internal I2C can implement the timeout (using internal timers).
    Cheers
    PeteS
  7. Bill Davy
    Bill Davy Guest
    I did find a bug in the Cypress I2C code which resulted in this. Fix is
    trivial, just stop the I2C when you see NACK:
    void i2c_isr(void) interrupt I2C_VECT
    { // I2C State Machine
    if(I2CS & bmBERR)
    I2CPckt.status = I2C_BERROR;
    else if ((!(I2CS & bmACK)) && (I2CPckt.status != I2C_RECEIVING))
    I2CPckt.status = I2C_NACK;
    I2CS |= bmSTOP; // RWD 8 June, 2005
    else
    Of course, not the whole solution, but every little helps.
    Bill
  8. sivadnz
    sivadnz Guest
    First came across this when reading 24C64's.
    We''ve also seen the same lockup where we share an I2C LCD display
    driver between 2 micro's, and the user rather crudly has a switch
    between micro A and micro B.
    The fix in both cases was as Piotr suggested, if bus is at fault, cycle
    the clock up to 9 times stopping when SDA goes high, then the bus is
    recovered.
    Regards Alec
  9. Bob Monsen
    Bob Monsen Guest
    This is usually a deadlock, caused by improper master control of the
    bus. Usually, the slave is waiting for you to clock something, and you
    are waiting for the slave to do something. If, for example, you forget
    to NACK the last read, you can get stuck in a state in which the slave
    thinks it's still talking.
    If this is happening, clocking the bus will eventually cause the slave
    to release SDA, because it wants to see your ack after 8 bits. If you
    leave SDA alone, it'll think it's a nack, and stop trying to write data
    to you.
    If the slave is holding SCL low, you are probably screwed.
    If the slave devices have a reset, use that instead of power. The FET
    thing makes sense if there isn't a reset pin. Note that if the device
    doesn't take too much power, you can just run it off of the
    microcontroller pin. I believe PICs have a limit of 20mA, which may be
    fine. I've done this with LCD displays before with no problem.
    Regards,
    Bob Monsen
    If a little knowledge is dangerous, where is the man who has
    so much as to be out of danger?
    Thomas Henry Huxley, 1877
