I Want To Fix My Trimmer
Discussion in 'Troubleshooting and Repair' started by MEeT, Apr 15, 2017.
  1. MEeT
    MEeT
    8
    Apr 15, 2017
    my trimmer's battry is down.but i have my samsung broken mobile charger it gives me 5V output volt.
    but my trimmer need 1.5 V so how i reduse voltage. plzz help me..
  2. davenn
    davenn Moderator
    13,812
    1,945
    what sort of trimmer ?
    hedge ?
    Grass ?
    nose hairs ?
    make and model with a link would be VERY helpful
  3. Alec_t
    Alec_t
    2,950
    803
    Jul 7, 2015
    What battery type? NiMH, lithium? ... ? (the type is probably indicated in small print somewhere on the trimmer body)
  4. MEeT
    MEeT
    8
    Apr 15, 2017
    Nimh AAA battry
  5. Alec_t
    Alec_t
    2,950
    803
    Jul 7, 2015
    What are you trying to do? Eliminate the battery and power the trimmer directly from the charger? Or just use the charger to charge the battery?
  6. MEeT
    MEeT
    8
    Apr 15, 2017
    Eliminate the battery and power the trimmer directlyfrom the charger?
  7. Alec_t
    Alec_t
    2,950
    803
    Jul 7, 2015
    What is the battery capacity (mAh) rating?
  8. (*steve*)
    25,490
    2,831
    The charger is almost certainly going to be unable to power the device.
    I'm sure it takes many times longer to charge the battery than it takes to run it flat.
  9. MEeT
    MEeT
    8
    Apr 15, 2017
    my trimmer works at 1.5V and my samsung mobile charger give me 5 volt so how i reduse voltage just tell me.plz
  10. Alec_t
    Alec_t
    2,950
    803
    Jul 7, 2015
    It's not just a matter of reducing the voltage.
    Do you know how much current the trimmer motor draws (the mAh rating of the battery, together with the number of hours trimming per battery charge you get, would give us a clue)?
    What is the mA rating of the charger?
  11. MEeT
    MEeT
    8
    Apr 15, 2017
    i dont know that
    plz go web site of trimmer and help me.
  12. Alec_t
    Alec_t
    2,950
    803
    Jul 7, 2015
    The web-site doesn't have the info. In post #8 I asked you for the battery capacity. What does the label on the battery say?
  13. MEeT
    MEeT
    8
    Apr 15, 2017
    it is nimh AAA battrry they dont print mah on that it is battry that used in our remote .
  14. Alec_t
    Alec_t
    2,950
    803
    Jul 7, 2015
    A battery of that size will typically have a capacity of ~500mAh to 1000mAh. If we assume 500mAh then a safe standard charging current would be, say, 40-50mA. It is likely, therefore, that the charger is rated for that sort of current. Your trimmer motor, however, will almost certainly draw a lot more than 50mA, particularly at start-up. Accordingly it is unlikely that the charger will power the motor (as Steve said).
