TheGlimmerMan said:
Perhaps. But you do not know a fucking damned thing about ground fault
bus bars in rack chassis. Your characterless, honorless cringe away from
arguing about your errant statement in that regard proves that fact.
You will never recoup your honor by merely touting your past.
You need to back up the bullshit claim you made.
Otherwise, you, just like the age and efficacy of the degree you might
have, are as obsolete as it can get.
The military inspectors didn't seem to have any problem with me? I
had to be there during their audit visits to answer questions.
And how did ground faults get into this, which you obviously do not
know much about?
You are starting to look like Sloman, side stepping, to get away from
what you do not know.
Ever hear of the old saying "You're in the dark" ?
Well in your cast, you would be in the dark with the obvious
knowledge base you hold. One dangerous person, to say the least.
While you are driving that automated garbage truck, you should stop
off at the public library for a little educational break, instead of
wasting your time fantasizing. It's evident that all you are doing is
wasting BW and use of a perfectly good computer.
Btw, you are getting dry with your commentary, can't you come up with
something better? You're becoming such a long and drawn out bore.
I would rather listen to Sloman. At least he can type up a good
screen full of rhetoric to make himself look interesting, with out
resorting to
colorful metaphors and back door drop out acronym english. If you want
to call it english? More like pig latin..
Jamie
