I think I got abducted...
Discussion in 'Twilight Zone' started by cjdelphi, Apr 3, 2022.
  1. cjdelphi
    cjdelphi
    1,162
    109
    Oct 26, 2011
    Ok I'm talking to people who design and build electronics so there for you are smart and can explain things the average person can not ..
    I have a UPS and when the power goes out you can hear the relay Clunk as the magnetic field collapses and the the inverter kicks in, I also have a security camera and an emergency red light that comes on when the power goes out...
    anyway power goes out, you can just about hear me or the misses snoring a second before the power goes out, the rumbling sound is the fridge compressor and that too goes out...
    so other than the red light in every frame from the emergency light...
    what is that search beam after the power gets knocked out by something silent as I don't hear a helicopter or car or anything else...
    listen to it carefully ....
    slowed down
    and slower
  2. kellys_eye
    kellys_eye
    4,717
    1,312
    Jun 25, 2010
    Potentially the IR filter on the camera cutting in/out as the light levels change.
  3. cjdelphi
    cjdelphi
    1,162
    109
    Oct 26, 2011
    that's fine however the onboard microphone doesn't make a sound when that happens ..
    turn up the volume, there's some kind if signal in the light beam, and the intensity of light stops outside my bedroom window, nobody elses...
    does IR light levels make the onboard microphone produce a sound as well? does an ir filter cutting in and out cause a black out?... if it does we're onto a winner
  4. cjdelphi
    cjdelphi
    1,162
    109
    Oct 26, 2011
    oh and I disabled the IR output because it blurs the image reflecting off the window, so it can not be that
  5. cjdelphi
    cjdelphi
    1,162
    109
    Oct 26, 2011
    helicopter makes sound ...
  6. kellys_eye
    kellys_eye
    4,717
    1,312
    Jun 25, 2010
    Any signs of sphincter enlargement? i.e. can you get a fist in there without touching the sides?
    If not I suggest you got away lucky...... or not - depends on your leaning......
  7. cjdelphi
    cjdelphi
    1,162
    109
    Oct 26, 2011
    nothing has changed, except your opinion on what it could be...
  8. Martaine2005
    Martaine2005
    4,092
    1,122
    May 12, 2015
    It’s ET phoning home.
    Martin
Similar Threads
Loading...
