Jean-Marie Vaneskahian
I Need To Trigger a Relay When an LED Lights Up On a Smoke Detector
My goal is to use simple battery operated combination Smoke / Carbon
Monoxide detectors in various parts of my house. I want these battery
operated detectors to trigger a simple contact closure when they
alarm.
I noticed that the detectors have a Red LED that lights up when the
Smoke / Carbon Monoxide detector is triggered. I soldered two small
wires to the PCB on the back of the detector in "parallel" with the
Red LED.
When I connect a voltmeter to the two wires I soldered in "parallel"
with the Red LED and now run from the back of the PCB of the Smoke /
Carbon Monoxide detector I get about +0.001V when nothing happens and
+1.78V when I hit the test button on the Smoke / Carbon Monoxide
detector. By the way, the Smoke / Carbon Monoxide detector runs on a
total of 3 AAA 1.5V batteries.
I have a very basic electronics understanding. One concept that I do
NOT understand is that of "Ground". I do understand how to "Wire"
components though.
My question is this:
How do I take the 2 wires running from the back of the PCB on the
Smoke / Carbon Monoxide detector and generate a basic dry "Contact
Closure" when the detector is triggered?
I am sure this requires transistors, diodes, resistors, reed switches
and a separate battery source, but I have no clue how to connect them
and what types and values to purchase. I buy most of these components
from Radio Shack (Part Numbers Would Be Great!).
Please help me put this together. I really appreciate any wisdom on
this topic. My goal is to protect my family by wiring these battery
operated Smoke / Carbon Monoxide detectors to my home alarm system
that uses contact closures.
Thanks a million in advance,
[email protected]
alarm.
Red LED.
components though.
[email protected]
