I need help (KVA)
Discussion in 'Electronic Basics' started by george, Apr 7, 2005.
  1. george
    george Guest
    I would like to know the Kva for the following appliances.
    4 freezers at 5 amps each
    3 chiller units at 3 amps each
    2 chillers at 35 amps each.
    I do not know if they are resistive or conductive(if that is necessary
    for the answer)
    Would the answer be 79 * 240 /1000 = 18.96??
    Hope you can help.
    Confused
  2. GotCoffee
    GotCoffee Guest
    If all you appliances are running off of 240 you're almost correct...
    you for got to add in the 4 freezers so add 20 more amps and you should
    come up with 23.76kVA
  3. Don Kelly
    Don Kelly Guest
    That is an upper limit - assuming all are running at the currents given and
    all are at the same power factor.[/QUOTE]
