reverse engineering
Steve, thanks for the reply. I will try and do as you say about removing the components. Without knowing what the National Semi can does, it will be hard to really figure out the circuits. What I do know is that a 7.7 ohm 3 watt wire wound resistor burned badly. This resistor is right at the input of the 28 volt power on the board and leads to a 15 volt device that acts like a zener diode, but has 3 legs. So I suspect something down the line is shorted and drawing too much current. The sensor in the wing (a varible capacitor depending on angle of attack) only has #28 wires, and they did not fry so I supect it is somewhere on the board. The device has a 5 amp circuit breaker that did not trip so I assume the resistor opened before it got to 5 amps which doesn't seem logical the way aircraft circuits are usually made.
