I Need A Battery Spring/Plate For A Device.
Discussion in 'Electronic Basics' started by DavidPI73, Oct 31, 2004.
  1. DavidPI73
    DavidPI73 Guest
    I have a portable electronic navigation system - a Pilot III from Garmin- which
    I use to find my way around the counties in the state where I work. It operates
    via batteries or by pluging it into the cigarette lighter.
    While using the navigation system, the batteries exploded. As I removed the
    batteries from the battery compartment, I accidently broke off the 1
    inch-by-half inch metal plate -with half-inch springs on it- attached to the
    edge of the battery compartment. I lost that part and and I need it replaced.
    I have been to Radio Shack, an auto parts accesory store, and a hardware store
    and none of them have that piece.
    Does anyone know how and where I can get this simple piece that has been
    getting considerbly more difficult to obtain than I had anticipated? Your help
    would be greatly appreciated. Thank you.
  2. Digikey sells quite a few springs and contacts:
    http://www.keyelco.com/kec/pdfs/p10.pdf
  3. DavidPI73
    DavidPI73 Guest
    Digikey sells quite a few springs and contacts: Thank you very much for taking the time to respond to my message. Would you
    know where I could get any dual coil battery contacts?
  4. Rich Grise
    Rich Grise Guest
    Where would you normally take the thing for repair anyway? Just ask
    them to order one for you.
    Good Luck!
    Rich
