Indian said:
The simpliest amount of part? Yank a dimmer from the salvage yard. No 555
needed.
Turn the knob and you go from about 5 - 1000 hz pulsating - 12V. I used
this trick to arc a coil. What're you making?
Indi
Thanks all.
A dimmer? Now that has me interested.
As to what I am making its just a test circuit because the circuit works
when hooked up to a 9 volt battery and it touches (arcs) between on and
off on the positive lead. Give it a steady 12vdc and it is next to not
working. Has me stumped so I figured had to want a pulsating DC and
since I have no source for that I can't test it.
