I just don't understand this...
Discussion in 'Electrical Engineering' started by Reverend Parson Peter Parsnip, May 19, 2004.
  1. Why does my portable stereo require 6 x type C 1.5V batteries... when they
    could simply have designed it to accept a square 9V battery?
    Any explanation?
    The Reverend Parson Peter Parsnip
    VISIT ME ONLINE AT: http://peterparsnip.blogspot.com/
    "Withhold not correction from the child: for if thou beatest him with
    the rod, he shall not die." -- Proverbs 23:13 (AV)
  2. ns
    ns Guest
    It's called capacity: those 9 V batteries have tiny cells (6 of them in
    series), each cell ~1/20 (or even less) of a type C cell.
    Those 9 V batteries are ~1/2 the price of 6 type C batteries, so the end
    result is very expensive proposition: you'll have to replace them very
    often.
  3. Garrett Mace
    Garrett Mace Guest
    To put it into more exact numbers, a Duracell C-size alkaline is about
    7100maH, and a Duracell 9-volt alkaline is about 600 maH. When you put the
    C-size batteries in series to get 9 volts, it's still 7100maH at 9 volts
    instead of 1.5 volts. So 7100maH / 600maH is 11.83 times the power. So for
    every set of C-size batteries, you'd go though about a dozen 9-volt
    batteries.
  4. [email protected] (Reverend Parson Peter Parsnip) wrote in
    A conspiracy involving duracell.
    Phil Kyle, Interweb Leg end
    http://philkyle2003.reachme.at/
    "Isn't a lowlife coward somebody who
    makes threats and promises yet fails
    to keep them? Hey, sounds like you, loser."
    - Craig "Fatboi" Oldfield
  5. ah
    ah Guest
    Thank you.
  6. "> "Withhold not correction from the child: for if thou beatest him with
    "But beatest an Iraqi detainee with a rod, and thou shall be court
    martialed"
    Gerald Newton 5/19/04
  7. Be still and pray homage to Gerald Newton who posted this on 20 May
    2004...
    ROTFL! Excellent.
  8. Be still and pray homage to ah who posted this on 20 May 2004...
    I agree! This has been bugging me for ages. I guess I should just learn
    more physics.
  9. ah
    ah Guest
    Damn objectivists . . . .
