I have an old Bose wave radio model AWR1-1W
mishpet
Nov 25, 2015
Nov 25, 2015
Hello I received an old Bose. I need to know what kind of antenna plug goes in it appears to screw on. I am going to order a power plug and want to get the antenna also. Thank you in advance for any help you can provide.20151125_090509_resized(1).jpg
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
It looks like an F-type female connector,does it have an outer thread ?
It can be connected to the wall FM antenna if there is one in the home,
or use a 75 ohm unbalanced F-type indoors antenna.
Note:
A short (about 30cm) "electric rigid wire " could do the job if you live in a place with good station coverage- worth a try before you spend money
rdamico
Sep 19, 2018
Sep 19, 2018
Same old FM reception issues with my Bose AWR1-1W too, but have since found good input, I'd like to follow up on: The power cord on these units also serves as antenna, the external 75 ohm antenna (not supplied w unit) works signicantly better - HOWEVER, using both will likely mess up reception as using 2 antennae often will with FM. The recommendation is to go with the inexpensive external with and Disconnect the antenna function on the power cord. Such a tuner modification seems worth following up on to me. The above info was relayed by a thorough Colorado Springs electronics outfit.
