I have a Zenith SR2773DT Losing Color
Discussion in 'Electronic Repair' started by D. E. Smith, Dec 30, 2003.
  1. D. E. Smith
    D. E. Smith Guest
    First off.. if this double posts, forgive me. My ISP was having an
    opportunity last night..
    I have a Zenith SR2773DT 27" TV that loses color once in anwhile. All I have
    to do is 'finaggle' the cable connector and the color will come in and out
    until I finally find a place where the color will stay for a while. It will
    eventually go out again and I will play with the input signal cable until
    the color shows again. I had the set to a tech, and they rebuilt the tuner,
    and repaired something else concerning the color signal. I had the set back
    to them 3 times, and the problem still exists. At least I got a rebuilt
    tuner out of it. Anyway, I was wondering if it could be something as simple
    as a bad RF connector? It seems weird to me that all I have to do is wiggle
    the cable a bit and the color will come back in. However, sometimes when I
    do this, I get bad snowy reception on my cable channels 33-39. All is well
    with the world if I change to channel 35 and wiggle the cable around until
    it comes in clear and in color. Sometimes I have to settle for just color,
    though. Any thoughts? Should I look for a new TV repair facility? Could it
    be as simple as the RF screw connector? Any help is appreciated.
    Dennis
  2. D. E. Smith
    D. E. Smith Guest
    OK.. OK.. forgot to include a ligit e-mail addy..
    Please read between the nospams and exchange the 'dot'
    [email protected]
  3. Art
    Art Guest
    Good possibility that the CRT may be going bad, may be best to have it
    inspected by a tech. Common problem with Zenith/Goldstar teles. Best 2004
  4. Jerry G.
    Jerry G. Guest
    Did you try the cable connection on another set to make sure that it is
    working properly. The connector on the cable side may be defective, or you
    do not have proper signal from the cable company considering that the set
    was properly serviced.
    You can call your cable company to check their feed, and verify their
    signal. They can come with a field strength meter, or a spectrum analyser
    to check their signal. Most cable companies also have their own portable TV
    sets for checking, if they customer wants to see a picture.
    However, it is possible that the tuner or the connection to it is not very
    good, and was not serviced properly. A snowy picture is due to a lack of
    signal, or a defect in the front end of the tuner, and or an RF AGE fault.
    If the picture signal gets too weak, it is normal to have a loss of colour.
    Considering the age of your set, and the bad reputation for the Zenith
    product you have, I would have not put any money in to that set. Since you
    are in to the repair, you may as well take a chance and pursue it.
    As for the value of a set, you would be better off in total performance, if
    you were to buy even a low end TV set to replace the one you have. The TV
    sets have improved greatly and the prices dropped sharply in the last 3
    years or so. With a new set, you would have a 2 or 2 year warranty to start
    with, and all the parts inside would be new.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    Dennis
  5. D. E. Smith
    D. E. Smith Guest
    I have put another set in place, and I have no reception or color problems,
    which to me rules out any cable issues. Could the problem be rectified by
    replacing the RF, or is there a deeper problem such as a picture tube going
    out? It just seems strange to me if it was something more serious, why then
    can I coax the color to show back up by moving the cable around?
    Thanks for the feedback!!
    Dennis
    sednospam55ATyahooDOTcom
  6. ToasterKing
    ToasterKing Guest
    Problems such as this are commonly the result of bad connections
    (solder or otherwise) in the tuner can or nearby on the main board. If
    the problem is in your picture tube, then you should not be able to
    affect the results by wiggling the cable. You may just try
    disassembling the TV and using the "toothpick test" to find any bad
    joints on the main board, then resolder them. One would hope that your
    rebuilt tuner isn't still the source of the problem.
    If your TV has separate video/audio RCA inputs, use those and connect
    the TV to an external video source such as a VCR or DVD player, then
    try wiggling the cables and connectors. This should make it clear
    whether the tuner in the TV is to blame.
    TK
  7. D. E. Smith
    D. E. Smith Guest
    When the set loses color, it loses it to the AV inputs, too. I just don't
    understand how "coaxing' the F connection would have anything to do with the
    AV connections, though. I would hate to pitch the TV.. it's only 6 yrs old.
    I am assuming that if the AV connections lose color too, that the problem is
    not in the tuner.
    Thanks for your input! If anything else comes to mind, please let me know!
    Dennis
  8. ToasterKing
    ToasterKing Guest
    That pretty much confirms it: the problem is not in your rebuilt
    tuner. It's likely a bad solder joint or otherwise a bad connection on
    the main board (to which the tuner can is attached). Slightly bending
    the board from direct pressure on the F connector of the tuner is
    probably exploiting the flawed connection by helping to make or break
    the already-marginal mating of the parts.
    If I were you, I'd take the set apart, get the main circuit board out
    while keeping all the important parts connected, power it on, and take
    a toothpick or other small insulative stick and poke around on the
    board until I could reproduce the problem. When I could narrow the
    offending joint down wo within a few inches, I'd then power down and
    resolder all the joints in the neighboring area, then test to see if
    the problem was resolved, and if not, repeat. If you plan on
    undertaking this project yourself and have never worked on a TV before,
    I HIGHLY recommend you read the TV repair FAQ and safety precautions at
    http://www.repairfaq.org and at least have an understanding of what not
    to touch, and how to discharge the CRT.
    Good luck!
    TK
