I have a good tek 2465
Discussion in 'Electronic Repair' started by tek_freak, Dec 22, 2007.
  1. tek_freak
    tek_freak Guest
    Works fine, but are there any recommended routine replacements for the
    no doubt aging caps in the power supplies??
    TIA!
    and happy holidays
  2. Meat Plow
    Meat Plow Guest
    I don't think replacing capacitors is part of a service routine :)
    I have an old Tek 453 scope and it's virgin inside and has been used
    extensively over the past couple decades I've owned it.
  3. Jim Yanik
    Jim Yanik Guest
    that's because it doesn't have any switching power supplies in it.
    They are tough on electrolytics.
    Their life will depend on how much use the scope gets.
  4. mike
    mike Guest
    That's a tough one.
    Rule number one: "if it ain't broke, don't fix it."
    But, there were a few years where electrolytics leaked and made
    a mess of the circuit board. At least look for little dots of
    electrolyte on the board near electrolytics.
    Then there's another time bomb waiting in electronic gear.
    Had a LCD monitor that had an open cap (actually just high ESR) in the
    switching regulator.
    The average voltage out was still 5V, but the peak voltage of 20V
    took out the electronics board.
    I think we're gonna see a LOT more of this type of failure in the coming
    decade.
    I'm still a fan of rule number one...
    mike
  5. Jim Yanik
    Jim Yanik Guest
    TEKs 1700 series of video monitors had an orange 1000uf/10v cap on it's 5v
    line,and the cap had too high an ESR,and the PS regulated off that 5v
    line,so when the cap began to fail,the OTHER supplies climbed really
    high,and the +40v unreg supply rose to +60 or more,and the PCB under the HV
    oscillator xstr charred due to the excess dissipation,and then became
    conductive and overloaded the PS,putting it into current limit("chirp" or
    burst mode").We even had caps burst open.
    I ended up Dremelling out the charred area,filling with epoxy,re-laying the
    traces and setting eyelets.(got to be pretty good at it)
    I had to do that on a lot of 1700 power supply boards,before we changed the
    1000uf /10v cap to a better grade low-ESR cap.Eventually,we changed vendors
    and all the electrolytics used were better grade,low ESR caps.
    That was one of my most common repair tasks,re-capping power supply
    boards(all switchers),throughout a number of TEK products.
