I have a friend who suffers with speech difficulties. I'm in need of some knowledge on electronic re
Jon
Hello if anybody can help me with this It would be brilliant to be able to
comunicate(even in a basic way) with my friend again. I don't know if I am
correct in posting here, I have a friend who suffers with speech
difficulties. I'm in need of some knowledge on electronic recording devices,
what I need is a device that could record requests like "can I have a cup of
tea" and repeat at the press of a button. I have no electronics experience,
but I am willing to learn, I have searched the web but there is so much and
where do you start. Can anybody advise me in which direction to go when
starting this project.
Thank you
Jon
Z
Zak
I'd think your friend may be very well off with a PDA that can play
sounds through a speaker. Check if it has a headphone plug that can be
wired into an amplifier.
The touch screen allows for a pretty user interface. I guess that can't
be too hard to write, but you can make it as nice as you want with a
sentence compose function even.
Thomas
G
Gareth
Thank you
Jon
Zak's suggestion of a PDA sounds like a good way to go. Another
completely different approach would be for you and your friend to learn
sign language.
D
Dana Raymond
How about using an iPod?
You can use your computer to record any words or phrases you wish, so long
as you have a mic input on your sound card or motherboard. Software can be
used to convert the sound bytes into a file format useable by the iPod, and
it has a great interface, 'songs' can be organized hierarchically, has room
for a massive about of recordings, and can be used to play music!
No engineering required.
Dana Frank Raymond
Jeroen Vriesman
You know the scientist Stephen Hawking?
He cannot speak anymore, and a lot of effort was put into a computer with
which he can speak, much more advanced than you can ever design yourself.
I know that the speech software is called "viavoice", and it's from IBM, a
while ago I downloaded it, and made my linux box speak, but I see that it's
not free anymore, and I cannot find the linux version at the moment.
Besides the speach software, you need to control it ofcourse, maybe peaple
at IBM know, or try to contact the university where Stephen Hawking works.
Good luck!
O
onestone
Hi Jon. There are literally thousands of devices out there that can help
your friend. Most of them over priced in my opinion. It very much
depends on several things. Firstly are your friends problems simply
related to speech, if so you can ignore the devices that have
sophisticated input devices for people with physical problems. Secondly
do you want a system that can say anything, or something with just a few
helpful phrases. Or both, usually different technologies are used for
each. Thirdly does your friend have any speech or vocalisation capability?
The sort of devices available include:-
Semantics processors that use graphical displays and icons who meaning
is both context and sequence sensitive, ie an icon of the sun may mean
outside/hot/burning etc depending upon what icons preceeded it and what
follow. These are usually expensive machines, design primarily for
people with slow input capability, making their speech rate faster.
Next come phrase based systems, these typically have banks of phrases
stored that allow sentences to be constructed, often these will have
some graphical interface, or overlay cards, so that you can select from
'sets' of words and phrases, making it unnecessary to have a key for
every one.
Finally there are the text entry type systems, some of these are
literally just type and talk affairs, with a keyboard and a speech
synthesiser. others are a little smarter and include features like type
ahead, where the most frequently used words are prestored. The downside
to this type of system can be speech quality, although the new Winbond
WS071 processors are streets ahead of the old robotic voice synhts of
the past.
I've built most types at different times, but most of my designs were
aimed at people with physical issues as well as speech problems, so were
typically restricted vocab designs. With many of these you can use an
analog voice recording chip, such as th ISD series from Winbond, and get
up to 16 minutes (last time I looked) of reasonable quality speech. By
programming this with common words and phrases you can get quite
apowerful system. On average (based on lots of TV recording and word
counting) a word, without silence, consumes 0.4 seconds, if you assume
that you can get 120 words stored per minute a 16 minute device can
offer quite a vocabulary, call it 1800 words, or about half the number
of words used frequently in conversation, and about a third the
vocabulary of most people, hence, with time, and judicious word
selection you could have human voice speech with a reasonable
vocabulary. You would then have a text entry system using a micro, and a
filing system to construct sentences with.
So two choices as I see it.
First option the Winbond ISD5216 speech storage system, add a micro with
enough grunt to work a file system and control the ISD part, add a
keyboard and a small display to see what is being entered, use 'type
ahead' or 'smart typing' to speed up data entry. This gives human
recorded voice, but is a lot of work entering the vocabulary. You can
enter it incrementally, but that's still a lot of work. Upside, you can
try and match voice and accent.
Second option use a text to speech processor like the Windbond WS071,
available in male and female voices. Then add a micro/keyboard/display
as above, perhaps type ahead, very similar hardware choices whichever
option you choose. This option gives an unlimited vocabulary, it has an
onboard 'dictionary' where you can teach it to correctly pronounce words
that synths find difficult, and quality has become quite good. Downside
is that it still isn't quite human voice.
There is a third option, which is to buy a commercial unit, but these
may be more limited than the solutions I describe, or extremely expensive.
Whichever option, if indeed you choose one of the two hardware
solutions, there is a lot of work involved. The keyboard, display and
type ahead stuff is generic, the synth requires an SPI interface, and
implementation of the reasonably simple protocol. The speech recording
system requires a lot of file system mainrenance software, and a lot of
sentence construction software to be written.
Both of the systems I describe are fully portable. You could implement
the text to speech system on a PC using the parallel port, but this
would tie you down.
The biggest expense in doing it yourself is the PCB. Rather than a
complex 32 key keypad I would opt for a simple 5 key data input. These
can be extremely fast with practice. I use one when I'm bedridden, that
I built myself, fits in the palm of my right hand, one thumb button, and
one under each finger tip, the thumb steps between character sets, mine
is for PC data entry so includes punctuation, this one wouldn't, just
the alphabet, space, numbers, backspace talk now etc. A nice clear large
character 16 x 2 LCD, cheap and adequate, an LM386 for the speaker,
digital volume control, and that's about it.
Al
R
R.Legg
Thank you
Jon
Free beta version of a text-to-speech converter for the PC is at
http://readplease.com/
RL
Z
Zero Lee
2nd Speech Center lets you listen to text instead of reading on
screen! It uses 'Text to Speech' technology to synthesize natural
sounding speech from ordinary text. Just copy text to the clipboard or
import from text files and listen as IISC reads it back to you!
2nd Speech Center also allows you to convert text into a MP3/WAV audio
file so you can listen later. Create MP3 files from your email, news
articles, any text you want, download to your portable MP3 player and
off you go!
Download URL(s) (2.62MB) -
http://www.qwerks.com/download/3727/iisc.zip
or
http://www.zero2000software.com/iisc.zip
Regards,
Zero Lee
WWW.ZERO2000.COM
WWW.ZERO2000SOFTWARE.COM
CD Catalog Expert - Catalog your CDs
2nd Speech Center - Listening instead of Reading
Akala EXE Lock - Password Protection for your EXE files
