I have a big trouble with usart PIC16f877
Discussion in 'Electronic Design' started by [email protected], Jun 26, 2006.
  1. Guest
    Hi everyone,
    I am having a big trouble with my PIC's serial communication. I have
    codes like these:
    GPS:
    CALL set4800
    A0: CALL RCread
    CALL TXsend
    XORLW 'G'
    BNZ A0
    MOVLW 0XFF
    MOVWF PORTA
    RETURN
    I have incoming messages and I want to take the one which starts
    with 'G', so I write these simple codes. Althoug I have sentences which
    starts with 'G', PortA never gets FF. I tried these codes with Proteus
    and it works. But it doesnt work with my pic16f877 in my circuit. From
    TX output I get the bytes which I sent from RC, I see that there are
    G's in RC but they dont make the port A to be FF. Please hellllppppp
    me.
    Here are my functions:
    RCread: bcf STATUS,RP0 ; Select Bank 0.
    getc1 btfss PIR1,RCIF ; Skip if RC int flag set
    goto getc1 ; Try again
    movf RCREG,W ; Read the character
    bcf PIR1,RCIF ; Clear the interrupt flag
    return
    TXsend bcf STATUS,RP0 ; Select Bank 0.
    putc1 btfss PIR1,TXIF ; Skip if TXbuffer empty
    goto putc1 ; Try again
    movwf TXREG ; Write it!
    return
    set4800: bsf STATUS,RP0
    MOVLW D'51'
    MOVWF SPBRG
    movlw 0xA4 ; CSRC/TXEN (Internal clock, 8 bit mode,
    Async
    ;operation,
    High Speed)
    movwf TXSTA ; Write to TX control register.
    BSF TXSTA,BRGH
    BCF STATUS,RP0 ;
    RETURN
  2. Ignoring the code for a while. How is the serial connected to the PIC?.
    Best Wishes
  3. Where are your initialization routines for TRISA, TRISC, TXSTA, RCSTA
    etc.? Are you setting up ADCON1 so you have digital outputs?
    Why do you keep clearing RP0, but ignore RP1?
    Your Fosc is 4MHz? You have an inverting RS-232 driver external to
    the chip?
    Is the echo working?
    Best regards,
    Spehro Pefhany
  4. You should read the Application note AN774 and try the sample code, which
    is an interrupt driven communication application:
    http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en012073
    This is the code it uses to check for a specific character:
    movf RCREG,W ;get received data
    xorlw 0x0d ;compare with <CR>
    btfsc STATUS,Z ;check if the same
    You need to check the STATUS register.
    Also, it looks like you are checking for the character you are
    transmitting, although it is the same as that previously received. It is
    usually a good idea to save and restore the W register when you call a
    function.
    Paul
  5. Default
    Default Guest
    Two possibilities come to my mind:
    1. Are you absolutely certain you are sending a "G" instead of a "g"?
    Forgive me if that isn't the source of your problem, but little things like
    that can waste lots of time and are suprisingly easy mistakes.
    2. The "BNZ" instruction doesn't exist in the PIC16F architecture. Have
    you defined some kind of macro named "BNZ" to emulate the functionality of a
    "Branch Not Zero" instruction? If you have, are you absolutely certain it
    works correctly? What kind of development tools/assembler are you using?
    The assembler that comes with MPLAB should barf like crazy if you select
    your processor type as 16F877 (although it would work on the PIC18F family
    of parts since they do include a BNZ instruction) and try to use a BNZ
    instruction.
  6. Default
    Default Guest
    Sweet. And here I've been wishing for that integrated capability all
    along...
  7. BNZ is a standard MPLAB assembler pseudo-instruction. It generates two
    instructions-- a BTFSS and a GOTO.
    Best regards,
    Spehro Pefhany
  8. gpsstajer
    gpsstajer Guest
    I am sending 'G' not 'g'. I have tried if the BNZ is working and I
    saw it works.
    Movlw 0x10
    xorlw 0x10
    bnz A0
    this code works. I still cant find a solution
  9. gpsstajer
    gpsstajer Guest
    The incomin wire into the RX, and the outcoming is out of TX. I checked
    the value of them from COM 1.
  10. I mean what electronics are between the wires and the chip...
    The chip expects TTL serial, not 'RS232'. A MAX232 or similar buffer chip
    is _required_ between the PIC and the PC. Without this, the input will be
    being overdriven, and the output will never work, and the signals will be
    inverted from what the PIC expects.
    Best Wishes
  11. gpsstajer
    gpsstajer Guest
    I thank you, all. I tried the solutions you suggeested me and I
    found the mistake. Because of the fast incoming messages my usart
    crashed. After every read operation, I reset the usart if there is an
    error. And it works correct. Here is the full program, I also made some
    changes with the configuration of USART. THANKS AGAIN
  12. gpsstajer
    gpsstajer Guest
    It is working :)
    #include <p16f877.inc>
    __CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _XT_OSC &
    _WRT_ENABLE_OFF & _LVP_OFF & _DEBUG_OFF & _CPD_OFF
    cblock 0x70
    temp
    endc
    org 0x0000
    reset clrf PCLATH
    goto main
    NOP
    NOP
    irq nop
    main: clrf STATUS ;main program
    BSF STATUS,RP0 ;durum kontrolü için kullanilacak portb'nin
    kosullanmasi
    clrf TRISA ;HATA durumlarinin kontrol edilecegi kütük
    clrf TRISD
    BCF STATUS,RP0
    call setUSART
    CALL GPSAL ;gps'den gelen veriler 1dk süre ile alinir
    RETURN
    GPSAL: CALL set4800
    MOVLW 0X00 ;for mutliplexer
    movwf PORTD
    A0: CALL RXget
    MOVWF temp
    CALL TXsend
    MOVF temp,W
    XORLW 'G'
    BNZ A0
    MOVLW '.'
    CALL TXsend
    MOVF temp,W
    CALL TXsend
    MOVLW 0XFF
    MOVWF PORTA
    goto GPSAL
    RETURN
    setUSART: bsf RCSTA,SPEN ; asyncron active
    bsf RCSTA,CREN ; rx active
    bsf STATUS,RP0 ;BANK1
    bcf TXSTA,SYNC ;asyncron active
    BSF TXSTA,TXEN ;tx active
    BSF TXSTA,BRGH ;High Baud rate
    movlw 0xc0 ;set tris bits for TX and RX
    iorwf TRISC,F
    BCF STATUS,RP0 ;AGAIN BANK0
    RETURN
    MOVLW D'51'
    MOVWF SPBRG
    BCF STATUS,RP0
    RETURN
    set19200: bsf STATUS,RP0
    MOVLW D'12'
    MOVWF SPBRG
    BCF STATUS,RP0
    RETURN
    RXget:
    getc1 btfSS PIR1,RCIF ; Skip if RC int flag set
    btfsc RCSTA,OERR ;if overrun error occurred
    goto ErrSerialOverr ; then go handle error
    btfsc RCSTA,FERR ;if framing error occurred
    goto ErrSerialFrame ; then go handle error
    btfss RCSTA,RX9D ;if first stop bit error occurred
    return
    TXsend btfsS PIR1, TXIF
    goto TXsend
    movwf TXREG
    bcf PIR1,TXIF ; Clear the interrupt flag
    return
    ErrSerialOverr:
    bcf RCSTA,CREN ;reset the receiver logic
    bsf RCSTA,CREN ;enable reception again
    return
    ;error because FERR framing error bit is set or first stop bit is zero
    ;can do special error handling here - this code simply clears and
    continues
    ErrSerialFrame:
    movf RCREG,W ;discard received data that has error
    return
    END
