I can't stop PWM signal. It is always active.
Discussion in 'Microcontrollers, Programming and IoT' started by Squalo, Apr 30, 2019.
  1. Squalo
    Squalo
    Apr 30, 2019
    Hi, i am new with MSP430.
    I would like to create a PWM signal when button is pressed to transmit IR signal and stop it after 50 miliseconds. But i cannot stop it.
    Here is my code
    #include <msp430.h>
    void startPWM(void);
    unsigned char counter=0;
    void stopPWM(void);
    int main(void)
    WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
    BCSCTL1 = CALBC1_1MHZ; // Set range
    DCOCTL = CALDCO_1MHZ;
    CCTL0 = CCIE;
    P2DIR |= BIT2; //IR transmitter
    P2SEL |= BIT2;// Select pwm pin (transmitter)
    P2OUT=0x00;
    while(1){
    if((P1IN & BIT4)!=BIT4) //button is pressed
    startPWM(); //send pwm
    stopPWM(); // stop after 50 ms
    void startPWM(void) // pwm signal
    TA1CCR0 = 26-1; // Period Register
    TA1CCR1 = 13; // 50% dutycycle
    TA1CCTL1 |= OUTMOD_6; // TA1CCR1, Reset/Set
    TA1CTL = TASSEL_1 + MC_1 + TACLR;
    void stopPWM(void) // trying to stop after 50 ms
    CCR0 = 5000; // CCR0 5 ms
    TACTL = TASSEL_2 + MC_2; //
    #pragma vector=TIMER0_A0_VECTOR // Timer0_A0
    __interrupt void Timer_A (void)
    if(++counter==10){ // is counter 10 (5*10=ms)
    TA1CCR1 = 0; ; // Stop timer so it can't send PWM signal
    counter = 0;
