i++ and ++i operator
Discussion in 'Microcontrollers, Programming and IoT' started by anukalp, Oct 1, 2018.
  1. anukalp
    anukalp
    14
    Jul 28, 2018
    What is the difference between ++i and ++i, both are increment, but i am confused with their operations.
    any one kindly make me understand how they both works and what is the output, the output is same i have tried.
    Code:
    int main()
       int x = 10;
       x++;
        printf("x is %d", x);
        return 0;
    x is 11
    and
    Code:
    int main()
       int x = 10;
       ++x;
        return 0;
    x is 11
  2. HellasTechn
    HellasTechn
    1,365
    192
    Apr 14, 2013
    I know little about C language but i think that it is exactly the same thing.
  3. Hopup
    Hopup
    217
    27
    Jul 5, 2015
    It is same thing in this context but it can be different thing when assigning variable for example.
  4. anukalp
    anukalp
    14
    Jul 28, 2018
    I don't think Its same thing
    Can you explain How its different ?
  5. Hopup
    Hopup
    217
    27
    Jul 5, 2015
    It would cause different result in example like this:
    A = 1;
    B = ++A;
    This results B = 2, A = 2
    A = 1;
    B = A++;
    This results B = 1, A = 2
    Harald Kapp likes this.
  6. (*steve*)
    25,085
    2,635
    If you study PDP-11 assembly language you'll see where many of C's features come from.
    The addressing modes of auto increment/decrement, deferral, and indirection provide 1 instruction implementation of many of C's arithmetic and pointer operations for a certain set of variable types. The various flags set after arithmetic operations and the operation of the compare instruction provide further insight into aspects of the C language.
    In many ways C reflects the desire to write low level code more easily on the PDP-11 predecesors and this closely reflects the architecture of this machine.
    Many years ago, as a lark, I wrote a couple of macros for the PDP-11 assembler which translated a small subset of simple C statements into assembler.
    The chicken and egg / pulling one's self up by the bootstraps implementation of the C compiler had it's early roots in something like this.
    GaryP74 and anukalp like this.
  7. Bluejets
    Bluejets
    3,104
    608
    Oct 5, 2014
    x++ gives value then increments
    ++x increments then gives value
    WWild and anukalp like this.
  8. anukalp
    anukalp
    14
    Jul 28, 2018
    This gives
    Code:
    int main(void)
       int a = 0;
       int b = a++;
       printf("Value of b is %d \n", b);
       printf("Value of a is %d \n",a);
       return 0;
    Value of b is 0
    Value of a is 1
    and
    Code:
    int main(void)
       int a = 0;
       int b = ++a;
       return 0;
    Value of b is 1
    Value of a is 1
    any reason When do you use ++a or a++ in program ?
  9. Hopup
    Hopup
    217
    27
    Jul 5, 2015
    Like bluejets stated, it is about the order how the code is processed. Like you can see in my example, when the increment is before the A, it is processed but when its after it is not processed before the creation of new variable.
    anukalp likes this.
Similar Threads
Loading...
